So where you have been configuring the certificate previously under 'Web-Server Profile' change this to be default. For example:
(Aruba7030) [mynode] (config) #web-server profile
(Aruba7030) [mynode] (Web Server Configuration) #captive-portal-cert default
Craig Syme
Original Message:
Sent: Jan 25, 2021 03:25 AM
Subject: Controller cant find certificate after controller config migration
Thanks for your repsonse.
How can I change the reference?
Bernd Borowski
Original Message:
Sent: Jan 23, 2021 02:42 AM
As a test, can you change the current certificate references to use the 'default' cert which is shipped with the box. Remove any traces of the existing certificate and re-upload the new certificate again?
Craig Syme
Original Message:
Sent: Jan 21, 2021 09:48 AM
I'm having trouble with a 7010 standalone controller . The config of that controller was migrated from an old one. Sadly I have no other information concerning that controller exchange.
I tried to upload and use another captive-portal certificate since the old one expired a few days ago. It seems to me though, that the old certificate has been uploaded and configured at the "mm" level and not the "mynode" level. When I try to change the old captive-portal servercertificate to the new one, the controller say, that no changes have been made and it switchs back to the old certificate. When I try to disable the configuration in CLI under
web-server profile
captive-portal-cert "xyz"
with a simple no it throws an error with the message >>server certificate "xyz" not found in path /sc<<.
When I try to delete the certificate via mgmt-surface or in cli it throws the error that this certificate is still in use.
Any suggestions what went wrong and how i can fix this?
Any help is appreciated.
Bernd Borowski
