Controller claims certificate CN for its own?
  • 1.  Controller claims certificate CN for its own?
    MVP
    Posted Jun 07, 2017 08:59 AM
    So I've got a wildcard certificate formed as follows:
    CN: host.domain.tld
    SAN1: host.domain.tld
    SAN2: *.domain.tld
    host.domain.tld is NOT the controller, this is another actual server. The controller should respond to captiveportal-login.domain.tld.
    I was trying to use (the wildcard portion of) this certificate on the controller for captive-portal auhentication.
    Now, this works. Guests get this valid certificate presented so no more cert errors.
    What is problematich however is that wireless users on the secure (non-guest) ssid, trying to access the server at https://host.domain.tld get redirected to https://host.domain.tld:4343 by the controller. The ip address also changes from the actual host to the controllers guest interface.
    I understand that the controller graps traffic for that CN for itself for guest users, but why is it intercepting dns requests for users on other SSID's?!
    Is this expected behaviour or what am I missing here?
  • 2.  RE: Controller claims certificate CN for its own?
    Posted Jun 07, 2017 09:04 AM
    What user role are those devices in?
  • 3.  RE: Controller claims certificate CN for its own?
    MVP
    Posted Jun 07, 2017 09:07 AM
    As simple and open as I can get it:
    (Aruba) #show rights user
    Valid = 'Yes'
    CleanedUp = 'No'
    Derived Role = 'user'
    Up BW:No Limit Down BW:No Limit
    L2TP Pool = default-l2tp-pool
    PPTP Pool = default-pptp-pool
    Number of users referencing it = 24
    Periodic reauthentication: Disabled
    DPI Classification: Enabled
    Youtube education: Disabled
    Web Content Classification: Enabled
    ACL Number = 78/0
    Max Sessions = 65535
    Check CP Profile for Accounting = TRUE
    Application Exception List
    Name Type
    Application BW-Contract List
    Name Type BW Contract Id Direction
    access-list List
    Position Name Type Location
    1 global-sacl session
    2 apprf-user-sacl session
    3 allowall session
    global-sacl
    Priority Source Destination Service Application Action TimeRange Log Expired Queue TOS 8021P Blacklist Mirror DisScan ClassifyMedia IPv4/6 Contract
    apprf-user-sacl
    allowall
    1 any any any permit Low 4
    2 any any any-v6 permit Low 6
    Expired Policies (due to time constraints) = 0
  • 4.  RE: Controller claims certificate CN for its own?
    MVP
    Posted Jun 07, 2017 09:17 AM
    As simple as I can get it: allowall.
    (Aruba) #show rights complete
    Valid = 'Yes'
    CleanedUp = 'No'
    Derived Role = 'complete'
     Number of users referencing it = 28
     ACL Number = 75/0
    Name  Type
    access-list List
    2         apprf-complete-sacl  session
    3         allowall             session
    global-sacl
    apprf-complete-sacl
    allowall
  • 5.  RE: Controller claims certificate CN for its own?
    Posted Jun 07, 2017 09:25 AM
    What's the output of "show datapath fqdn"?
  • 6.  RE: Controller claims certificate CN for its own?
    MVP
    Posted Jun 07, 2017 09:28 AM
    host.domain.tld
  • 7.  RE: Controller claims certificate CN for its own?
    Posted Jun 07, 2017 09:33 AM
    That's why. You shouldn't​ use shared certificates from the rest of your environment with the controller. Use a dedicated certificate with an appropriate common name for your controllers.
  • 8.  RE: Controller claims certificate CN for its own?
    MVP
    Posted Jun 07, 2017 09:38 AM
    ok, that's the current behaviour.. understood.
    But can you explain why the controller would intercept DNS requests on an SSID where no role is configured to do so? Is there a good reason to do this?
    It might be easier to except this truth if I understand the why of it :)
  • 9.  RE: Controller claims certificate CN for its own?
    Posted Jun 07, 2017 09:42 AM
    Because the controller will take the CN and add it as the redirect address in the controller when you import it.
