Aruba Airwave
Controller Config Missing
  • 1.  Controller Config Missing
    Posted Nov 10, 2022 03:49 AM
    Hi!
    I am new to AirWave. I got this issue. After moving an AP to other group, Controller Config and other sub menus in the group disappears. The global config is set to "No".
  • 2.  RE: Controller Config Missing
    Posted Nov 10, 2022 11:28 AM
    Each configuration group in Airwave has it's own configuration, and has a setting for the types of devices that can be in that group.
    It probably is that you don't have enabled the Instant AP Device Type for the group APs; hence you don't see the Instant configuration options.
