controller configs that dont mach
  • 1.  controller configs that dont mach
    Posted Jan 07, 2015 04:12 PM
    I have 2 720 controlers that were installed by a certified vendor 1 year ago, and when i look at the configs in a program like Beyond Compare they do not match.  it is not just ip info it is stuff like ip access list, ip session info ect  my question is should they not be the same and how do i make them the same.
  • 2.  RE: controller configs that dont mach
    Posted Jan 07, 2015 04:14 PM
    Are they master-local or master-master?
  • 3.  RE: controller configs that dont mach
    Posted Jan 07, 2015 04:16 PM
    Master local
  • 4.  RE: controller configs that dont mach
    Posted Jan 07, 2015 04:17 PM
    If you run show switches on the master, what do you see for the status of the local?
  • 5.  RE: controller configs that dont mach
    Posted Jan 07, 2015 04:24 PM
    (psd-master01) #show switches
    All Switches
    IP Address Name Location Type Model Version Status Configuration State Config Sync Time (sec) Config ID
    10.81.0.9 psd-master01 Gig Harbor, WA master Aruba7220 6.4.2.3_47524 up UPDATE SUCCESSFUL 0 67
    10.81.0.14 psd-local01 Gig Harbor, WA local Aruba7220 6.4.2.3_47524 down UPDATE REQUIRED 0 0
  • 6.  RE: controller configs that dont mach
    Posted Jan 07, 2015 04:29 PM
    All Switches
    ignore the down state the second controler is disconected from the network for now.  i will have it back online mometarily.
  • 7.  RE: controller configs that dont mach
    Posted Jan 07, 2015 04:30 PM
    Once it comes back online, run the command again and see if the update is
    successful.
  • 8.  RE: controller configs that dont mach
    Posted Jan 07, 2015 04:35 PM
    All Switches
    10.81.0.14 psd-local01 Gig Harbor, WA local Aruba7220 6.4.2.3_47524 up UPDATE SUCCESSFUL 9 67
  • 9.  RE: controller configs that dont mach
    Posted Jan 07, 2015 04:34 PM
    All Switches
    controllers up now reran command
  • 10.  RE: controller configs that dont mach
    Posted Jan 07, 2015 04:38 PM
    And are the configs still different? (other than basic network settings)
  • 11.  RE: controller configs that dont mach
    Posted Jan 07, 2015 04:51 PM
    What version is each controller at and what is the licensing installed on each? Is centralized licensing configured? For each controller run:
    show image ver
    show license
    show license aggregate (master-only)
  • 12.  RE: controller configs that dont mach
    Posted Jan 07, 2015 07:50 PM
    (psd-master01) #
    (psd-master01) #show image ver
    Partition : 0:0 (/dev/usb/flash1)
    Software Version : ArubaOS 6.3.1.5 (Digitally Signed - Production Build)
    Build number : 43118
    Label : 43118
    Built on : Tue Apr 8 20:55:04 PDT 2014
    Partition : 0:1 (/dev/usb/flash2) **Default boot**
    Software Version : ArubaOS 6.4.2.3 (Digitally Signed - Production Build)
    Build number : 47524
    Label : 47524
    Built on : Sat Dec 6 10:15:29 PST 2014
    (psd-master01) #show license
    License Table
    Key Installed Expires Flags Service Type
    yvXjLth+-Hh8OVbVZ-9XkMjLIK-ug385JuW-mz6ac5In-fyw 2014-01-21 Expired Next Generation Policy Enforcement Firewall Module: 2048
    06:34:03[2]
    aOHLry9N-inR8XTR0-2gZVVdpC-i0m/TXY8-fLISknbL-mrg 2014-03-04 Expired Access Points: 2048
    12:39:56[3]
    ZMx7ZViT-2+7bWIDV-3qeA7r1l-ZFCJIXOp-wBPkGx6s-zB0 2014-02-13 Never E Access Points: 32
    09:40:35
    wIxk9xrP-s25gLHZB-tCGZvVac-OqQTVPNZ-dVG1+3mx-hVI 2014-02-13 Never E Next Generation Policy Enforcement Firewall Module: 32
    09:40:45
    y1/s4Lf+-loINyyGg-NpUY0gSk-eLQsZas7-brSI7/2B-08o 2014-02-13 Never E Next Generation Policy Enforcement Firewall Module: 384
    09:40:54
    8t1/QIFZ-VG/T65PA-07C1kMv2-6IOcw2Dq-Az+MdkLC-sjA 2014-02-13 Never E Next Generation Policy Enforcement Firewall Module: 64
    09:41:03
    V8DIhIlL-mZNuasqq-MZL3IeWM-7wo9EAWW-UtXtx05S-27I 2014-02-13 Never E Access Points: 16
    09:41:11
    i9nXmMgQ-9z0wFTEM-GkyOvN+D-YVagT+Q9-Fjuaf2YS-tHA 2014-08-13 Never E Access Points: 128
    14:13:27
    5owumel1-mvkgMaKy-vGjtCzYr-IL0DbTUa-95hTTkuk-XZk 2014-08-13 Never E Next Generation Policy Enforcement Firewall Module: 32
    14:17:35
    cizUPLyI-75VzD0Cr-HF45nhvJ-e53mFZWK-OYUxlj/C-hSs 2014-08-13 Never E Access Points: 32
    14:17:58
    License Entries: 10
    Flags: A - auto-generated; E - enabled; R - reboot required to activate
    (psd-master01) #show license ?
    aggregate License aggregate table
    client-table License client-table entries
    debug Show debugging information about centralized
    licensing
    heartbeat License heartbeats
    limits Current license limits
    profile Show the License provisioning profile
    server-redundancy License Server Redundancy Configuration
    server-table License server-table entries
    verbose Verbose output (deprecated, output is always
    verbose)
    | Output Modifiers
    (psd-master01) #show license aggregate
    Aggregate License Table
    Hostname IP Address AP PEF RF Protect xSec Module ACR Last update (secs. ago)
    psd-local01 10.81.0.14 560 304 0 0 0 13
    psd-master01 10.81.0.9 208 512 0 0 0 14
    Total AP License Count :768
    Total PEF License Count :816
    Total RF Protect License Count :0
    Total XSEC License Count :0
    Total ACR License Count :0
    (psd-master01) #
  • 13.  RE: controller configs that dont mach
    Posted Jan 07, 2015 07:53 PM
    I will find out in the am
    Paul
  • 14.  RE: controller configs that dont mach
    your local needs an update.
    Try doing a 'write memory' on the master and run 'show switches' again to see if the update is successful. The write memory will push down configuration from the master to the local
    Make sure your Master configuration is correct though before doing the write memory
  • 15.  RE: controller configs that dont mach
    Posted Jan 07, 2015 04:18 PM
    the controllers are master-local
