Controller DNS Server and Gateway
This thread has been viewed 21 times
  • 1.  Controller DNS Server and Gateway
    Posted Nov 06, 2012 11:31 AM
    Can I configure multiple gateways using (ip default-gateway command) ?
    Which 'show' command will show me the gateway address configured ?
    How to configure DNS server IP address for the controller using command line (without using DHCP) ?
  • 2.  RE: Controller DNS Server and Gateway
    Posted Nov 06, 2012 01:37 PM
    Yes, you can configure multiple default gateways.  "show ip route" will let you view which routes are configured.  Use the "ip default-gateway x.x.x.x" command.  If you don't specify a cost for the route, it will be equal to the one you have now.
    You can configure a DNS server using:
    ip domain lookup
    ip name-server x.x.x.x
  • 3.  RE: Controller DNS Server and Gateway
    Posted Mar 19, 2013 01:23 PM
    Our controller is trunked to a core router. Can we have specific gateways for each VLAN the controller has? What will be the cost associated with it? If we already have 1 gateway with a cost of 1, having another gateway for a different subnet with thesame cost shoud not matter?
