Controller doesnt update AP
  • 1.  Controller doesnt update AP
    Posted Mar 04, 2019 06:18 AM
    in my setup I'm using 2 accesspoints:
    ArubaOS (MODEL: 303), Version 8.3.0.6
    One of them is the master.
    I have one SSID with enterprise authentification. It seems that the master doesn't send the configuration to the second accesspoint. Because in the area of the master ap I can connect to this SSID and in the area from the other ap i can't connect.
    How can I check if the configuration is correct on the second ap? Is there an error log or something which I should check?
    Thanks and regards!
  • 2.  RE: Controller doesnt update AP
    MVP EXPERT
    Posted Mar 04, 2019 06:23 AM
    Are these Aruba Instant or attached to a physical controller? If these are Instant AP, have they joined the same cluster? Run the below on the 2nd AP to confirm what is being broadcast.
    #show ap essid
    #show aps
  • 3.  RE: Controller doesnt update AP
    Posted Mar 04, 2019 06:33 AM
    #show ap essid
    #show aps
    They are instant - there's no physical controller. How can I check if they are in the right cluster?
    From my prefered master (AP2) i get the following:
    AP2# show ap essid
    % Parse error
    AP2# show aps
    2 Access Points
    Name  IP Address      Mode    Spectrum  Clients  Type         IPv6 Address  Mesh        Role  Zone  Serial #    radio0 Channel  radio0 Power (dB)  radio0 Utilization (        %)  radio0 Noise Floor (dBm)  radio1 Channel  radio1 Power (dB)  radio1 Utilizat        ion (%)  radio1 Noise Floor (dBm)  Need Antenna Config  From Port  Config Id  Co        nfig Csum  Ext SSID Active  Age         Link Local IP Address
    AP2   172.29.163.49*  access  disable   0        303(indoor)  --            N/A        -     CNG2K9T4G7  52E             22                 12(good)        -92(good)                 1               19                 9(good)        -95(good)                 No                   none       1          90        46         enable           1h:38m:31s  --
    AP1   172.29.163.48   access  disable   0        303(indoor)  --            N/A        -     CNG2K9T4GN  52E             22                 13(good)        -92(good)                 6               19                 20(good)        -96(good)                 No                   none       1          90        46         enable           1h:37m:15s  --
    And from AP1:
    AP1# show aps
    0 Access Point
    Name  IP Address  Mode  Spectrum  Clients  Type  IPv6 Address  Mesh Role  Zone  Serial #  radio0 Channel  radio0 Power (dB)  radio0 Utilization (%)  radio0 Noise Floor (dBm)  radio1 Channel  radio1 Power (dB)  radio1 Utilization (%)  radio1 Noise Floor (dBm)  Need Antenna Config  From Port  Config Id  Config Csum  Ext SSID Active  Age  Link Local IP Address
    AP1#
  • 4.  RE: Controller doesnt update AP
    MVP EXPERT
    Posted Mar 04, 2019 06:46 AM
    Thats good, they are both in the same cluster. Are you able to run the following command on each IAP and confirm if they are broadcasting the SSID's?
    #show ap bss-table
    And the following to see if there is any uncommitted configuration.
    show uncommitted-config
    Also why are these both configured with the same 5Ghz (52E) channel?
  • 5.  RE: Controller doesnt update AP
    Posted Mar 04, 2019 06:51 AM
    AP1# show ap bss-table
    Aruba AP BSS Table
    bss                ess                port  ip             phy    type  ch/EIRP/max-EIRP  cur-cl  ap name  in-t(s)  tot-t       flags
    80:8d:b7:1d:14:50  Gerstner-Zentrale  ?/?   172.29.163.48  a-VHT  ap    52E/22.6/22.6     0       AP1      0        1h:59m:38s
    80:8d:b7:1d:14:40  Gerstner-Zentrale  ?/?   172.29.163.48  g-HT   ap    6/19.8/19.8       0       AP1      0        1h:59m:38s
    Channel followed by "*" indicates channel selected due to unsupported configured channel.
    "Spectrum" followed by "^" indicates Local Spectrum Override in effect.
    Num APs:2
    Num Associations:0
    Flags:       K = 802.11K Enabled; W = 802.11W Enabled;
    AP2# show ap bss-table
    Aruba AP BSS Table
    80:8d:b7:1d:4b:50  Gerstner-Zentrale  ?/?   172.29.163.49  a-VHT  ap    52E/22.6/22.6     0       AP2      0        1h:59m:50s
    80:8d:b7:1d:4b:40  Gerstner-Zentrale  ?/?   172.29.163.49  g-HT   ap    1/19.7/19.7       0       AP2      0        1h:59m:49s
    Num APs:2
    Num Associations:0
    show uncommitted-config is on both APs empty
    I don't know why they are on the same channel. I thought they manage the channels by themselfes...
  • 6.  RE: Controller doesnt update AP
    MVP EXPERT
    Posted Mar 04, 2019 06:53 AM
    The output shows they are broadcasting 1 SSID on each of the APs. So both APs have the same configuration. It is likely to be another issue either with the authentication or VLANs.
    Have you added the IAP as a NAS client on your NPS or enabled Dynamic RADIUS Proxy on the IAP?
    Are the VLANs correct on the secondary switch port where AP2 is connected?
  • 7.  RE: Controller doesnt update AP
    Posted Mar 04, 2019 06:58 AM
    Yes, they broadcast the same SSID. This is what I want :)
    The problem is, that users can only connect on AP2. When they try to connect on AP1 they get an error which says something like "not able to connect to the network". We tried it with iPhones, Android, Windows 10 and Mac OS.
  • 8.  RE: Controller doesnt update AP
    MVP EXPERT
    Posted Mar 04, 2019 07:02 AM
    What does the reject on your authentication server say? Is the NAS Client IP/VLANs correct?
  • 9.  RE: Controller doesnt update AP
    Posted Mar 04, 2019 07:09 AM
    Thanks a lot.
    I only added AP2 to our NAS. After adding AP1 it's working.
    One more question: Should I change something with the channels?
  • 10.  RE: Controller doesnt update AP
    MVP EXPERT
    Posted Mar 04, 2019 07:13 AM
    No worries, you can always used Dynamic RADIUS Proxy which hides all RADIUS
    requests behind the single VC IP and not the individual AP IP Addresses.
    ARM should adjust the channels. How far apart are the APs, if they cannot
    hear each other then this maybe the reason why 52E is selected on both.
  • 11.  RE: Controller doesnt update AP
    Posted Mar 04, 2019 07:17 AM
    OK. Thanks a lot! :)
