Controller downloading user roles from CPPM
  • 1.  Controller downloading user roles from CPPM
    Posted Jan 30, 2018 08:30 AM
    Could anybody explain
    1. how controller downloads user roles from CPPM ?
    2. Is it via https connection ? If yes, how CPPM certificate is generated and how root certificate of CPPM is copied to controller ?
    3. Workflow details of controller to CPPM connection during downloading of user roles?
    Thanks in advance.
  • 2.  RE: Controller downloading user roles from CPPM
    Posted Jan 30, 2018 10:01 AM
    HTTPS using a username/password.
  • 3.  RE: Controller downloading user roles from CPPM
    Posted Jan 30, 2018 11:55 AM
    Thanks for the reply.
    To successfully establish HTTPS connection with CPPM, is it required to copy the root certificate of CPPM to certstore of controller ? If yes what is the procedure to load the root certificate to the store.
    What is the procedure to create/install certificate required for HTTPS connection in CPPM ?
    Thanks in advance.
  • 4.  RE: Controller downloading user roles from CPPM
    Posted Jan 30, 2018 11:56 AM
    No. Just define the username and password in the server definition.
  • 5.  RE: Controller downloading user roles from CPPM
    Posted Jul 29, 2019 05:21 PM
    how can we do that on Mobility Controller 8.5?
    Could you give us a procedure ?
    Than you
