Controller IAP VPN routing
  • 1.  Controller IAP VPN routing
    Posted Oct 25, 2015 12:44 PM
    Hello group,
    I'm a bit lost on the moment ;-)
    Trying to get a IAP105 to connect over the internet in Local-Mode to a OAW4030 controller by Aruba-IPsec VPN (split tunnelling).
    I did config the IAP for VPN, wifi-network and local DHCP scope, did configure the controller for the IAP-user and whitelist-db rap.
    The VPN tunnel is *Up* and I can ping from a wifi connected laptop to the internet, also I can
    ping the the controller internal IP address 192.168.13.253/24 over the tunnel.
    I can even SSH login to the controller internal IP address, it shows in the log that I did login from the SNAT address I did get from the controller. Also the web page from the controller is working on that IP address in the browser!
    That looks very nice, but I can only reaches the controller IP address!
    If I want to ping a other system (192.168.13.2) in the same subnet as the controller IP, the controller will not route the traffic to the subnet. I did run a tcpdump on that system but nu icmp-echo packets reach the IP.
    On the "show interface vlan 13" the interface shows "Routing interface is enable, Forwarding mode is enable".
    Why is the controller not routing in the 192.168.0.0/16 network?
    OAW-IAP105, Version 6.4.3.1
    OAW-4030, Version 6.4.3.3
    With kind regards,
    Fred Krom.
  • 2.  RE: Controller IAP VPN routing
    Posted Oct 25, 2015 09:09 PM
    Fred,
    Does the IAP mac address appear on the controller's cli if you issue the show iap table command?
    Also, is the IAP managed by Airwave or Central? If not you have to issue the following commands:
    iap trusted-branch-db allow-all
    or
    iap trusted-branch-db add mac-address<mac-address>
    I have recently had a problem similar to yours that was fixed by this method.
    Let me know if that helps!
    Ben
  • 3.  RE: Controller IAP VPN routing
    Posted Oct 26, 2015 05:06 AM
    Hi Ben,
    Thanks for answering!
    Yes I did play with it for some time and found the command you mention.
    The output looks OK to me and I will add the output in this message.
    The controller is a life running system with some campus AP's connected to it, the IAP is only one device and I did the config by hand (gui & cli) and did not use AirWave.
    Because there is traffic possible from the wifi laptop to the controller IP address I expect something in the controller routing (datapath). I’m using static routing and ospf is not used.
    I will try this evening the "iap trusted-branch-db allow-all" to see if that will be different.
    (OAW-4030) #show iap trusted-branch-db
    Trusted Branch Validation: Enabled
    IAP Trusted Branch Table
    Branch MAC
    24:de:c6:XX:Xf:51
    (OAW-4030) #show iap table
    IAP Branch Table
    Name VC MAC Address Status Inner IP Assigned Subnet Assigned Vlan
    AP105 24:de:c6:XX:Xf:51 UP 192.168.224.126
    (OAW-4030) #ping 192.168.224.126
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 192.168.224.126, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 18.493/18.689/18.936 ms
    Fred
  • 4.  RE: Controller IAP VPN routing
    Posted Oct 26, 2015 07:58 AM
    do you have any routing rules created on the IAP to direct 192.168 traffic to corporate??
  • 5.  RE: Controller IAP VPN routing
    Posted Oct 26, 2015 08:04 AM
    Yes, created first:
    routing-profile
      route 192.168.0.0 255.255.0.0 192.168.13.253
    later test it with:
    routing-profile
      route 192.168.13.0 255.255.255.0 192.168.13.253
    Maybe also important:
    (OAW-4030) #show ip route
    Codes: C - connected, O - OSPF, R - RIP, S - static
    M - mgmt, U - route usable, * - candidate default, V - RAPNG VPN/Branch
    Gateway of last resort is Imported from DHCP to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from CELL to network 0.0.0.0 at cost 10
    Gateway of last resort is Imported from PPPOE to network 0.0.0.0 at cost 10
    Gateway of last resort is 212.203.27.1 to network 0.0.0.0 at cost 20
    S* 0.0.0.0/0 [20/0] via 212.203.27.1*
    S 10.0.0.0/8 [10/0] via 192.168.13.254*
    S 172.16.0.0/12 [10/0] via 192.168.13.254*
    S 192.168.0.0/16 [10/0] via 192.168.13.254*
    C 192.168.13.0/24 is directly connected, VLAN13
    C 10.0.4.0/22 is directly connected, VLAN540
    C 192.168.11.0/24 is directly connected, VLAN11
    C 192.168.4.0/23 is directly connected, VLAN4
    C 192.168.7.0/24 is directly connected, VLAN7
    C 212.203.27.0/25 is directly connected, VLAN500
    C 192.168.224.126/32 is an ipsec map 89.99.104.xxx-192.168.224.126
    (OAW-4030) #show interface vlan 13
    VLAN13 is up line protocol is up
    Hardware is CPU Interface, Interface address is 00:0B:86:xx:x1:A7 (bia 00:0B:86:xx:x1:A7)
    Description: 802.1Q VLAN
    Internet address is 192.168.13.253 255.255.255.0
    IPv6 Router Advertisements are disabled
    Directed broadcast is disabled, BCMC Optimization disabled ProxyARP disabled Suppress ARP enable
    Encapsulation 802, loopback not set
    MTU 1500 bytes
    Last clearing of "show interface" counters 8 day 15 hr 42 min 27 sec
    link status last changed 8 day 15 hr 40 min 32 sec
    Proxy Arp is disabled for the Interface
    Fred
  • 6.  RE: Controller IAP VPN routing
    Posted Oct 26, 2015 09:40 AM
    have you tried setting the gateway of the route to the public IP instead of the private?
  • 7.  RE: Controller IAP VPN routing
    Posted Oct 26, 2015 10:18 AM
    Hi Pasquale,
    That is a interesting suggestion!
    I will try it this evening if it works.
    Fred
  • 8.  RE: Controller IAP VPN routing
    Posted Oct 26, 2015 04:10 PM
    Hi Pasquale,
    I did changed the routing-profile to:
    routing-profile
      route 192.168.13.0 255.255.255.0 212.203.27.xxx
      route 10.0.0.0 255.255.252.0 212.203.27.xxx
    The effect is the same still only 192.168.13.253 is pingable (and ssh / https).
    The DHCP setting used is this one:
    ip dhcp VLAN20
      server-type Local
      server-vlan 20
      subnet 192.168.20.0
      subnet-mask 255.255.255.0
      lease-time 2700
      dns-server 208.67.222.222,208.67.220.220
    Fred
    Did collect some commands on the VC and controller.
    -- VC:
    24:de:c6:xx:xf:51# show ip route
    Kernel IP routing table
    Destination Gateway Genmask Flags MSS Window irtt Iface
    212.203.27.xxx 192.168.0.1 255.255.255.255 UGH 0 0 0 br0
    192.168.13.253 0.0.0.0 255.255.255.255 UH 0 0 0 tun0
    192.168.100.0 0.0.0.0 255.255.255.0 U 0 0 0 br0
    192.168.20.0 0.0.0.0 255.255.255.0 U 0 0 0 br0
    192.168.0.0 0.0.0.0 255.255.255.0 U 0 0 0 br0
    0.0.0.0 192.168.0.1 0.0.0.0 UG 0 0 0 br0
    24:de:c6:xx:xf:51# show ip interface
    Interface IP Address / IP Netmask Admin Protocol
    br0 192.168.0.2 / 255.255.255.0 up up
    24:de:c6:xx:xf:51# show datapath acl-rule ict
    Datapath SSID: ict ACL Entries
    Flags: P - permit, L - log, E - established, M/e - MAC/etype filter
    S - SNAT, D - DNAT, R - redirect, r - reverse redirect m - Mirror
    I - Invert SA, i - Invert DA, H - high prio, O - set prio, C - Classify Media
    A - Disable Scanning, B - black list, T - set TOS, t - time based, o - tunnel only
    K - App Throttle, s - Domain SA, d - Domain DA, 4 - IPv4, 6 - IPv6
    ACL Name {ict 0} Number {130}
    1: any any 17 0-65535 8209-8211 P4
    2: 192.168.20.0 255.255.255.0 192.168.13.0 255.255.255.0 any 192.168.224.127 PS4 hits 340
    3: 192.168.20.0 255.255.255.0 10.0.0.0 255.255.252.0 any 192.168.224.127 PS4 hits 1
    4: 192.168.20.0 255.255.255.0 192.168.20.0 255.255.255.0 any P4 hits 325
    5: 192.168.20.0 255.255.255.0 224.0.0.0 224.0.0.0 any P4 hits 460
    6: 192.168.20.0 255.255.255.0 any any masterip PS4 hits 3076
    7: any any any P4 hits 67
    ACL Name {ict 1} Number {131}
    2: 192.168.20.0 255.255.255.0 192.168.13.0 255.255.255.0 any 192.168.224.127 PST4
    3: 192.168.20.0 255.255.255.0 10.0.0.0 255.255.252.0 any 192.168.224.127 PST4
    4: 192.168.20.0 255.255.255.0 192.168.20.0 255.255.255.0 any PT4
    5: 192.168.20.0 255.255.255.0 224.0.0.0 224.0.0.0 any PT4
    6: 192.168.20.0 255.255.255.0 any any masterip PST4
    7: any any any PT4
    24:de:c6:xx:xf:51#
    routing-profile
    ip dhcp VLAN20
      server-type Local
      server-vlan 20
      subnet 192.168.20.0
      lease-time 2700
    -- Controler:
    Branch MAC
    24:de:c6:xx:xf:51
    (OAW-4030) #show whitelist-db rap
    AP-entry Details
    Name AP-Group AP-Name Full-Name Authen-Username Revoke-Text AP_Authenticated Description Date-Added Enabled Remote-IP
    24:de:c6:xx:xf:51 AP_HOME 24:de:c6:xx:xf:51 Provisioned Thu Oct 22 13:18:57 2015 Yes 0.0.0.0
    IAP Branch Table
    AP105 24:de:c6:xx:xf:51 UP 192.168.224.127
    Total No of UP Branches : 1
    Total No of DOWN Branches : 0
    Total No of Branches : 1
    (OAW-4030) #ping 192.168.224.127
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 192.168.224.127, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 21.221/34.3046/42.999 ms
    (OAW-4030) #ping 192.168.13.2
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 192.168.13.2, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 0.147/0.1772/0.276 ms
  • 9.  RE: Controller IAP VPN routing
    Posted Oct 27, 2015 07:09 PM
    I did find the problem!
    The internal interface 192.168.13.253 did have the "Inter-VLAN Routing" enabled, but the external interface did not. The IPsec tunnel terminate on that interface I expect, and that interface will not route the package out of the device (internal it will route).
    Fred
