Controller integration with OneLogin
  • 1.  Controller integration with OneLogin
    Posted Oct 21, 2015 02:36 PM
    Hi Forum,
    I don't have any experience with OneLogin and want to ask if the aruba controller is able to integrate with OneLogin as a Radius or auth server? without ClearPass in the play.
  • 2.  RE: Controller integration with OneLogin
    Posted Oct 21, 2015 02:58 PM
    If it is a normal RADIUS server, yes.
  • 3.  RE: Controller integration with OneLogin
    Posted Oct 21, 2015 03:01 PM
    Thanks Tim. not sure what you mean by "normal".
    it is a radius server that is a cloud based.
  • 4.  RE: Controller integration with OneLogin
    Posted Oct 21, 2015 03:02 PM
    Yes should work then. Question is do you really want your management
    authentication in the cloud? :)
  • 5.  RE: Controller integration with OneLogin
    Posted Jan 12, 2016 11:51 PM
    were you able to get it working?
  • 6.  RE: Controller integration with OneLogin
    Posted Apr 16, 2016 04:12 PM
    Tim, how can I do that?
    Looks like AIs support only PEAP-GTC and PEAP-MSCHAPv2, but onelogin supports only PAP or EAP-TTLS/PAP
    Are there any possibilities to get EAP-TTLS/PAP working on AIs?
  • 7.  RE: Controller integration with OneLogin
    Posted Apr 16, 2016 04:29 PM
    You need to use a RADIUS server. The APs are EAP-agnostic.
  • 8.  RE: Controller integration with OneLogin
    Posted Apr 16, 2016 04:33 PM
    OneLogin have Radius server onboard, but it only supports PAP and EAP-TTLS/PAP => doesn't work with AIs
    https://onelogin.zendesk.com/hc/en-us/articles/202361670
  • 9.  RE: Controller integration with OneLogin
    Posted Apr 16, 2016 04:35 PM
    Instant is EAP-agnostic, it should work if you define OneLogin as the radius server.
  • 10.  RE: Controller integration with OneLogin
    Posted Apr 16, 2016 04:38 PM
  • 11.  RE: Controller integration with OneLogin
    Posted Apr 16, 2016 04:52 PM
    Most devices do not support EAP-TTLS without a configuration profile or custom supplicant. What type of device are you testing with?
  • 12.  RE: Controller integration with OneLogin
    Posted Apr 17, 2016 11:10 AM
    Tim, that means protocol is defined on client? Cool, I'll check on Monday
  • 13.  RE: Controller integration with OneLogin
    Posted Apr 18, 2016 06:17 PM
    Tim, I checked it today, everything is working perfect.
    For Mac OS X I used Apple Configurator 2 to create profile for EAP-TTLS/PAP, then it can be easily applied to all laptops.
    Not tried, but it should work out of the box with Linux, Android and modern versions of Windows (8+).
    Thank you very much!
