Network Management
Controller interface monitoring
  • 1.  Controller interface monitoring
    Posted Apr 02, 2015 07:13 AM
    I'm new to using Airwave and wanted to know if there was a way to monitor a controllers physical port and be alerted if it goes down. I can't see that this exists in the triggers - only an interface usage which I can put in a vaule that creates a trigger when exceeded.
  • 2.  RE: Controller interface monitoring
    Posted Apr 02, 2015 07:59 AM
    You would do this:
    1.  Configure your controller to send syslog to your airwave server:
    config t
    logging <ip address of Airwave>
    2.  Setup a trigger that looks for the syslog message for an interface being down:
    An interface down syslog message looks like this: (type show log network all)
    Mar 19 19:27:00 :209801:  <WARN> |fpapps|  Physical link down: port 1/2
     You would configure a trigger for that by looking for the words "Physical link down":
  • 3.  RE: Controller interface monitoring
    Posted Apr 02, 2015 08:18 AM
    Thank you - I will give this a try.
  • 4.  RE: Controller interface monitoring
    Posted May 06, 2015 03:37 AM
    I have tested this and it works as expected, Thank you.
