Controller Issue
  • 1.  Controller Issue
    Posted Nov 10, 2014 10:18 AM
    i have a Aruba 3600 controller with 172.16.0.0 vlan [vlan 1].[dhcp enabled]
    Now i am implement another vlan [vlan 2] of 172.17.0.0 network assigned in port  3. [dhcp enabled]
    now when i plug a ap in port 3 [vlan 2] its getting ip of 172.17.0.0 network and identify is master as 172.168.0.254. but controller cant show the ap.
    vlan 1 = dhcp 172.16.0.0 network.
    vlan 2 = dhcp 172.17.0.0 network.
    please tell me now what i have do.
    how can this ap broadcast ssid?
    thanks in advance.
    #3600
  • 2.  RE: Controller Issue
    Posted Nov 10, 2014 10:38 AM
    Change the IP address of your master :
    interface vlan 1
    no ip address
    ip address dhcp-client
    and then do controller-ip vlan 1
    And in your AP System-Profile to IP it picked.
    I suggest to use a static IP for your controller instead.
  • 3.  RE: Controller Issue
    Posted Nov 10, 2014 10:47 AM
    look my controller already have a static ip which is 172.16.0.254.
    ap can recognise it as a master. But the problem is controller cant recognise the ap.
    Ap on different vlan [vlan2 = 172.17.0.0]
    controller on different vlan [vlan1=172.16.0.0]
    in vlan 2 dhcp [172.17.0.0] working fine, it gives dynamic ip to ap.
  • 4.  RE: Controller Issue
    Posted Nov 10, 2014 10:50 AM
    Do you have CPSec enabled ? show control-plane-security
    Have you installed licenses ? show ap license-usage
  • 5.  RE: Controller Issue
    Posted Nov 10, 2014 10:55 AM
    yeah. the cpsec is on and all the licence is installed.
