controller License
  • 1.  controller License
    Posted Feb 14, 2017 04:06 AM
    I have master/standby topology, i dowload certificate on the master controller and us this certificyate in securtiy->authentication->L2 authentication, (the certificate name is the controller name, and master name is diffrent from standby name).
    I noticed that the certificate from master was not moved to standby,
    Can i import diffrent certificate to standby ?
    Is it problematic since i have database sync ?
    Regards
    Rafi
    Security > Authentication > L2 Authentication
  • 2.  RE: controller License
    MVP EXPERT
    Posted Feb 14, 2017 05:09 AM
    Hey, you can check that the database sync is working as expected by running #show database sync
    According to the documentation only the WMS, Local User and CPSEC DB are sync'd (along with running configuration) between the two master controllers.
  • 3.  RE: controller License
    Posted Feb 14, 2017 06:26 AM
    Ok,
    can i add different license to the second controller,
    To do so the second controller must change his role to master is it ok ?
    Regards
    Rafi
  • 4.  RE: controller License
    Posted Feb 14, 2017 09:05 AM
    @Rafish wrote:
    Ok,
    Regards
    Rafi
    Do you want the controllers to share licenses?  If yes, you should turn on centralized licensing.
  • 5.  RE: controller License
    Posted Feb 14, 2017 08:37 AM
    @Rafish wrote:
    Regards
    Rafi
    You must upload a certificate individually to each controller.  The controller certificate is not synchronized with database sync.
  • 6.  RE: controller License
    Posted Feb 15, 2017 04:06 AM
    Hi Colin,
    Fisrt thanks alot for your help :)
    Ok, i did that, i upload the cer to the standby, in the standbty everthing is "gray" and i can't add the certificate to the profile so i shut down the master , then the standby change to master, under the profile i added the certificate and i got error:
    Error processing command 'aaa authentication dot1x "my-profile-name" server-cert "CCAMC7220D"':Unknown Trusted CA Certificate. Please upload the certificate before configuring in the profile
    I upload the certificate from GUI, and i can see them, but when i checked with
    show dot1x certificates details
    I noticed that i dont have any certificate on the standby controller.
    Any idea ?
    Regards
    Rafi
  • 7.  RE: controller License
    Posted Feb 15, 2017 04:46 AM
    You mentioned "licenses" and you mentioned "certificates".  Which one are you having problems with?
  • 8.  RE: controller License
    Posted Feb 15, 2017 04:55 AM
    Sorry,
    I have problem with the certifaicate on the standby controller.
    I have two controllers active and standby i create csr on both of them.
    On the master everything is ok, the problem i mentioned is on the standby.
    Regards
    Rafi
  • 9.  RE: controller License
    Posted Feb 15, 2017 05:39 AM
    Did you submit the CSR on the standby controller to a CA?
  • 10.  RE: controller License
    Posted Feb 15, 2017 07:52 AM
    Sorry i didnt understand what do you mean by "submit the CSR..."
    See attached print screen from the standby controller
    Management > Certificates > Upload
    Regards
    Rafi
  • 11.  RE: controller License
    Posted Feb 15, 2017 08:08 AM
    Based on your first post, it seems like the controller does not think the Controller Server Certificate was signed by the CA Certificate you uploaded.
  • 12.  RE: controller License
    Posted Feb 15, 2017 09:01 AM
    I created CSR on each controller and upload them to the controller.
    How can i go from ?
    Is there spaciel way to add certificate to the standby controller ?
    Regards
    Rafi
  • 13.  RE: controller License
    Posted Feb 16, 2017 02:14 AM
