controller license active CAPS doesn't match GUI's
  • 1.  controller license active CAPS doesn't match GUI's
    Posted Apr 01, 2019 11:11 PM
    Hi everyone,
    I use command "show license-usage ap" and I found that 126 APs in use,But I use GUI and I found only 119 in use.
    What would cause this ?And How many AP left can I add actually?
    (AC01) #show license-usage ap
    AP Licenses
    Type Number
    AP Licenses 128
    PEF Licenses 128
    Overall AP License Limit 128
    AP Usage
    Type Count
    Active CAPs 126
    Standby CAPs 0
    RAPs 0
    Remote-node APs 0
    Tunneled nodes 0
    Total APs 126
    Remaining AP Capacity
    Type Number
    CAPs 2
    RAPs 2
    (AC02) #show license-usage ap
    AP Licenses
    Type Number
    AP Licenses 2
    PEF Licenses 2
    Overall AP License Limit 2
    AP Usage
    Type Count
    Active CAPs 0
    Standby CAPs 119
    RAPs 0
    Remote-node APs 0
    Tunneled nodes 0
    Total APs 119
    Type Number
    CAPs 0
    RAPs 0
  • 2.  RE: controller license active CAPS doesn't match GUI's
    Posted Apr 01, 2019 11:41 PM
    What is the firmware version? The information on the cli is correct information. show ap active After running the show ap database command Check the amount of AP actually connected Looks like GUI display error
  • 3.  RE: controller license active CAPS doesn't match GUI's
    Posted Apr 01, 2019 11:59 PM
    Thank you for your reply
    (AC01) #show version
    ArubaOS (MODEL: Aruba3600), Version 6.4.3.7
    show ap active :Num APs:119
    show ap database status up:Total APs:119
    show license-usage ap  Active CAPs :126
    Actually It is 119 APs online
