I am getting the error in one of the controller(7010).
I would like to know the reason for that.
fpapps[3314]: <399801> <ERRS> |fpapps| An internal system error has occurred at file porfidio_poe.c function hapiGrappaPoePortGetStatus line 177
HI ,
What is the Image version and what are the devices connected to the controller ?
Please clarify the above.
this is likely to be bug 96147, fixed in 6.4.3.z or 6.4.2.7 (or higher). It is a cosmetic error, but upgrade should solve it
regards
-jeff
