last person joined: 7 hours ago
Controller Log - An internal system error has occurred at file channel.c function ch_check line 1410
  • 1.  Controller Log - An internal system error has occurred at file channel.c function ch_check line 1410
    Posted May 18, 2016 06:33 AM
    Hi All,
    We have a Aruba 7010 controller running 6.4.2.9 version. We are getting a list of logs related to APs for internal system error.Users are unable to connect to Corporate WiFi at site. Will this error cause issue to connect to WiFi network.
    Logs
    " AP DL00-LA009@172.31.248.15 sapd|  An internal system error has occurred at file channel.c function ch_check line 1410 error default_ch_cnt ."
    Internal System error is for all the APs.
    User Logs
    " User Authentication failed. username=MAC ADDRESS userip=0.0.0.0 usermac=MAC servername=xx_xxx_1 serverip=<IP> apname=DL00-LA012 bssid=<Radio MAC>"
    "Authentication server request Timeout, username=MAC ADDRESS userip=0.0.0.0 usermac=MAC servername= xx_xxx_1 serverip= <IP> bssid=<Radio MAC> apname=DL-LA008"
    Regards
    PRD
  • 2.  RE: Controller Log - An internal system error has occurred at file channel.c function ch_check line 1410
    Posted May 18, 2016 06:40 AM
    That Channel.C error message might be cosmetic.  What is the error number?
    It looks like your users cannot get on because your AAA server is not responding.
  • 3.  RE: Controller Log - An internal system error has occurred at file channel.c function ch_check line 1410
    Posted May 18, 2016 08:32 AM
    Thanks Colin,
    Here is the complete log . And this error is for each of the APs.
    May 18 19:17:37  sapd[1749]: <326268> <ERRS> |AP IDBDG-LA010@172.31.248.142 sapd|  An internal system error has occurred at file channel.c function ch_check line 1410 error default_ch_cnt 0 .
    May 18 19:17:37  sapd[1799]: <326268> <ERRS> |AP IDBDG-LA006@172.31.248.141 sapd|  An internal system error has occurred at file channel.c function ch_check line 1410 error default_ch_cnt 0 .
    May 18 19:17:38  sapd[1749]: <326268> <ERRS> |AP IDBDG-LA010@172.31.248.142 sapd|  An internal system error has occurred at file channel.c function ch_check line 1410 error default_ch_cnt 0 .
    May 18 19:17:38  sapd[1773]: <326268> <ERRS> |AP IDBDG-LA004@172.31.248.134 sapd|  An internal system error has occurred at file channel.c function ch_check line 1410 error default_ch_cnt 0 .
    Also before these logs we received a lot of errors regarding interference on multiple channels
    May 18 19:15:56  wms[3493]: <126005> <WARN> |wms| |ids| Interfering AP: The system classified an access point (BSSID <Radio MAC> and SSID OPPO F1f on CHANNEL 6) as interfering. Additional Info: Detector-AP-Name:IDBDG-LA011; Detector-AP-MAC:<MAC>; Detector-AP-Radio:2.
    May 18 19:16:01  wms[3493]: <126005> <WARN> |wms| |ids| Interfering AP: The system classified an access point (BSSID <Radio MAC> and SSID kuto1 on CHANNEL 1) as interfering. Additional Info: Detector-AP-Name:IDBDG-LA010; Detector-AP-MAC:<MAC>; Detector-AP-Radio:2.
    May 18 19:17:23  wms[3493]: <126005> <WARN> |wms| |ids| Interfering AP: The system classified an access point (BSSID <Radio MAC> and SSID the abinda's on CHANNEL 3) as interfering. Additional Info: Detector-AP-Name:IDBDG-LA010; Detector-AP-MAC:<MAC>; Detector-AP-Radio:2.
    May 18 19:17:33  wms[3493]: <126005> <WARN> |wms| |ids| Interfering AP: The system classified an access point (BSSID <Radio MAC> and SSID Andromax-M2Y-F852 on CHANNEL 11) as interfering. Additional Info: Detector-AP-Name:IDBDG-LA006; Detector-AP-MAC:<MAC>; Detector-AP-Radio:2.
    Regards
    PRD
  • 4.  RE: Controller Log - An internal system error has occurred at file channel.c function ch_check line 1410
    Posted May 18, 2016 09:22 AM
    That "interference" is just foreign access points that the system can see.  It does not mean there is severe interference.
  • 5.  RE: Controller Log - An internal system error has occurred at file channel.c function ch_check line 1410
    Posted May 19, 2016 09:18 AM
    The same error is found on multiple locations now in different controllers for all the APs. Is this error really servcie affecting and can disconnect users from WiFi network.
     <326268> <ERRS> |AP DL-LA005@172.31.248.13 sapd|  An internal system error has occurred at file channel.c function ch_check line 1410 error default_ch_cnt 0 .
    Regards
    PRD
  • 6.  RE: Controller Log - An internal system error has occurred at file channel.c function ch_check line 1410
    Posted May 19, 2016 10:06 AM
    What is the AP type and what regulatory domain is this?
  • 7.  RE: Controller Log - An internal system error has occurred at file channel.c function ch_check line 1410
    Posted May 19, 2016 11:14 AM
    Thanks Colin,
    AP type is 225 and Regulatory domain is Indonesia (ID).
    802.11G channels - 1,6,11
    802.11a channels - 149,153,157,161
    802.11g 40MHz channel pair - 1-5,7-11
    802.11a 40MHz channel pair - 149-153 , 157-161
    802.11a 80MHz channel group - 149-161
    Regards
    PRD
  • 8.  RE: Controller Log - An internal system error has occurred at file channel.c function ch_check line 1410
    Posted May 20, 2016 01:35 PM
    o_O
  • 9.  RE: Controller Log - An internal system error has occurred at file channel.c function ch_check line 1410
    Posted May 20, 2016 04:13 PM
    This is all I see for ID.  You should not have 40mhz channels for the AP225..
    (Aruba7640-US) #show ap allowed-channels country-code ID ap-type AP-225
    Allowed Channels for AP Type AP-225 Country Code "ID" Country "Indonesia"
    PHY Type                 Allowed Channels
    802.11g (indoor)         1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (indoor)         149 153 157 161
    802.11g (outdoor)        1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (outdoor)        149 153 157 161
    802.11g 40MHz (indoor)   None
    802.11a 40MHz (indoor)   None
    802.11g 40MHz (outdoor)  None
    802.11a 40MHz (outdoor)  None
    802.11a 80MHz (indoor)   None
    802.11a 80MHz (outdoor)  None
    802.11a (DFS)            None
  • 10.  RE: Controller Log - An internal system error has occurred at file channel.c function ch_check line 1410
    Posted May 23, 2016 08:09 AM
    Thanks a lot Colin. This will certainly help.
    This error "An internal system error has occurred at file channel.c function ch_check line" does not seem to affecting the WiFi network.
    Thanks again Colin for a quick response and I will check for 40MHz channel on AP225 for ID country code and will let you know.
    Regards
    PRD
