Controller management access lockdown
  • 1.  Controller management access lockdown
    Posted Nov 26, 2019 04:20 PM
    I am new to Aruba and I would like to change 2 things on my new controller 9004 which I use mainly for vpn access.
    1. Disable mgmt web access to the interface outside ( public) https://X.X.X.X:4343/login.html. I want only interface inside ( internal ) to be used for web mgmt, ones a user is securely connected via vpn from outside.
    2, I want new via users to be able to reach the webside where via install files can be downloaded https://X.X.X.X:4343/via but as I mentioned before I do not want to get anyone access to web gui for mgmt.
    Thank you for help :)
  • 2.  RE: Controller management access lockdown
    Posted Dec 01, 2019 05:17 PM
    you can check the AOS hardening guide from here.
    https://support.arubanetworks.com/Documentation/tabid/77/EntryId/16036/DMXModule/512/Default.aspx
    There is a section on "Locking Down Administrative Access"
  • 3.  RE: Controller management access lockdown
    Posted Dec 02, 2019 06:20 PM
    Thank You for the answer :-)
