Controller Migration Strategy
  • 1.  Controller Migration Strategy
    Posted Jun 02, 2014 09:50 AM
    I'm upgrading a single 3600 controller to a  (2) 7200master-master controller setup.  What's the best approach to doing this?  My current idea is to join one the first 7200 controller with the old 3600 controller in master-master between them, test, then replace the 3600 with the other 7200.  What are your thoughts, and any gotcha's that I may be overlooking?
    #3600
  • 2.  RE: Controller Migration Strategy
  • 3.  RE: Controller Migration Strategy
    Posted Jun 02, 2014 10:10 AM
    I've already migrated 3600 to single 7200.  I'm asking more about migrating from single to multi.
  • 4.  RE: Controller Migration Strategy
    Posted Jun 02, 2014 10:22 AM
    Is it going to be Active-Active or Active-Standby ?
  • 5.  RE: Controller Migration Strategy
    Posted Jun 02, 2014 10:23 AM
    Active-Standby with VRRP and db synch between them.
  • 6.  RE: Controller Migration Strategy
    Posted Jun 02, 2014 10:29 AM
    Both controllers will be in the same L2 segment ?
    To migrate existing config from the 3600 to 7200 (Active Master)
    - Upgrade the 3600 to 6.2 and Up
    - Add the 7200 as a local to the 3600 that way it will push the config
    - Add the licenses
    - Then Make the 7200 a Master
    -  Follow this :
    http://www.arubanetworks.com/vrd/CampusWNetworksVRD/wwhelp/wwhimpl/common/html/wwhelp.htm#context=CampusWNetworksVRD&file=Chap5_Redundancy.html
  • 7.  RE: Controller Migration Strategy
    Posted Jun 04, 2014 10:37 AM
    What if there is no L2 between the controllers?
    The controllers will be going in 2 separate Datacenters, so I guess I'll have to do LMS/BLMS type redundancy?
  • 8.  RE: Controller Migration Strategy
    Posted Jun 04, 2014 10:50 AM
    You can also use HA for your APs if you are running 6.3 AOS.
  • 9.  RE: Controller Migration Strategy
    Posted Jun 04, 2014 11:30 AM
    Unfortunately there are are SSIDs that are locally bridged, and according to the documentation HA only works when the SSIDs are tunneled.
  • 10.  RE: Controller Migration Strategy
    Posted Jun 04, 2014 06:23 PM
    What if there is no L2 between the controllers? The controllers will be going in 2 separate Datacenters, so I guess I'll have to do LMS/BLMS type redundancy?
    That is correct.
    In this case you configure Master/Local so this way both controllers will have the same consistent config
