Controller / Mobility Master 2FA
  • 1.  Controller / Mobility Master 2FA
    Posted Sep 18, 2020 11:07 AM
    Hello all,
    Please can you let me know if it is possible to use two factor authentication to log into the GUI on Mobility Controllers or Mobility Master. We can use ClearPass if needed.
  • 2.  RE: Controller / Mobility Master 2FA
    Posted Nov 04, 2021 11:44 AM
    I guess the answer is No...lol
    Kirk Christensen
  • 3.  RE: Controller / Mobility Master 2FA
    Posted Nov 04, 2021 11:47 AM
    If you are using Clearpass, then you have the option to forward the authentication to a 2FA server.  As long as the timeout isn't exceeded, this should be transparent to the Mobility Controllers/Master.
