Controller not responding
  • 1.  Controller not responding
    Posted Jan 10, 2013 04:20 PM
    we have some strange problems with our setup:
    We have a single 3400 Controller which is sometimes not responding on any webserver-port. No WEB-GUI, no Captive Portal. A few seconds (or minutes, or sometimes hours) later, anything is fine... There are no problems to access the Controller via SSH.
    We checked some things:
     - There are no STP-Options enabled on the whole networks setup
     - we have a CPU-Load at about 1%
     - there are only about 10 Clients connected
     - there are no DoS-Attacks or somethings similiar to that
     - we tried different Software-Versions (6.1.3.6 at the moment)
     - we tried to access the controller via different physical ports, directly at the front of the controller - same mistake.
     - we checked all available logs for errors - nothing
    So any idea? TAC?
    #3400
  • 2.  RE: Controller not responding
    Posted Jan 10, 2013 11:38 PM
    Have you confirmed there is not an IP conflict?  Can you give the controller another IP to see if it responds?
  • 3.  RE: Controller not responding
    MVP EXPERT
    Posted Jan 11, 2013 05:36 PM
    Maybe it is an issue with the httpd (apache) process? Do you see anything if you do show cpuload current? Or
    show ipc statistics httpd stm ?
  • 4.  RE: Controller not responding
    Posted Jan 12, 2013 06:50 AM
    @connect55 wrote:
    So any idea? TAC?
    Yes, TAC.
