last person joined: 7 hours ago
controller not saving
  • 1.  controller not saving
    Posted Sep 05, 2014 01:30 PM
    Hi
    I have aruba 3400 controller. suddenly it is not saving anything, for example i am trying to provision a AP to a group but when i change it and apply it is not working . i have logged in to the console of the ap and change the group. please help
    #3400
  • 2.  RE: controller not saving
    Posted Sep 05, 2014 01:48 PM
    What version AOS are you running ? Is this only happening with one AP?
    Have you tried using another browser ?
    You could also try provisioning through the controller CLI:
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/provision-ap-ip-address-via-the-controller-command-line/td-p/151168
  • 3.  RE: controller not saving
    Posted Sep 05, 2014 01:56 PM
    tried in another browser still the same and it is for all AP. And i am not able to add wlan. i have to configure it through cli. the wlan wizard is not working. i
    Model:Aruba3400-US
    Version:6.1.3.4
  • 4.  RE: controller not saving
    Posted Sep 05, 2014 02:43 PM
    Check the logs and see what might be failing
    show log system 50
  • 5.  RE: controller not saving
    Posted Sep 05, 2014 03:22 PM
    do you also provision your APs via a wizard? because the wizards have been known to act strange. i would try to clear the cache and try again and if it keep failing with other browsers / browser versions.
  • 6.  RE: controller not saving
    Posted Sep 08, 2014 01:35 PM
    browser issue most likely.. faced that several.times... try with IE with aruba it is the best browser to use.
