Controller of Controllers
  • 1.  Controller of Controllers
    Posted Jul 05, 2018 11:11 AM
    Hi Experts,
    If we have a huge deployment with Multiple COntrollers, can we have a Master Controller to manage all different Controllers centrally?
    Thanks a lot
  • 2.  RE: Controller of Controllers
    Posted Jul 06, 2018 07:58 AM
    You posted this question in the controllerless forum. Is your question about Instant (controllerless) or controller networks?
    If you have many Aruba Instant clusters, you should have a look at Aruba Central (cloud management) or Aruba Airwave if you prefer on-premise solutions.
    In case of controllers, you probably want to look at the ArubaOS 8 architecture which as a Mobility Master, which does what you describe. Check here for the ArubaOS 8 Fundamentals Guide.
  • 3.  RE: Controller of Controllers
    Yes, there are several options depending on the ArubaOS version you are running:
    - For ArubaOS 6.x: you can configure a master/local setup where the master manages the configuration of the local controllers. You can find more info here (chapters 3 and 5)
     - https://www.arubanetworks.com/vrd/CampusWNetworksVRD/wwhelp/wwhimpl/js/html/wwhelp.htm#href=Chap5_Redundancy.html
    - For ArubaOS8: all the config is handled in the Mobility Master. More info here: http://www.catelsys.com/v3/wp-content/uploads/2017/04/0-Notices-ArubaOS-8.0.1.0-User-Guide.pdf
    HTH
    Kevin
