controller port is not negotiating duplex and speed
  • 1.  controller port is not negotiating duplex and speed
    Posted Jan 22, 2020 01:38 AM
    i have the problem with the second port of aruba 7210 controller, it is not coming up and showing up as "down" as mentioned below. not able to negotiate speed and duplex
    UAM-CLCAR-MB02MDF-WC01) # show interface gigabitethernet 0/0/1
    GE 0/0/1 is up, line protocol is down
    Hardware is Gigabit Ethernet, address is 00:1A:1E:02:29:C2 (bia 00:1A:1E:02:29:C2)
    Description: UNI_CH_CARR2_CAT_13 port 2/17 (RJ45 Connector)
    Encapsulation ARPA, loopback not set
    Configured: Duplex ( AUTO ), speed ( AUTO ) >>>>>>>>>>>>>>>>>>>> not negotiating speed and duplex setting automatically
    MTU 1500 bytes, BW is 100 Mbit
    Last clearing of "show interface" counters 3 day 7 hr 23 min 48 sec
    link status last changed 2 day 8 hr 54 min 24 sec
        5522239 packets input, 2874019978 bytes
        Received 379533 broadcasts, 0 runts, 0 giants, 0 throttles
        0 input error bytes, 0 CRC, 0 frame
        95095 multicast, 5142706 unicast
        2032351 packets output, 1132726950 bytes
        0 output errors bytes, 0 deferred
        0 collisions, 0 late collisions, 0 throttles
    This port is TRUSTED
    output from the switchport
    un-ula-chlcar2-csw001#show interfaces gigabitEthernet 2/10
    GigabitEthernet2/10 is down, line protocol is down (notconnect)
      Hardware is Gigabit Ethernet Port, address is 006b.f1fd.5671 (bia 006b.f1fd.5671)
      Description: UAM-CLCAR-MBMDF-WC01
      MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
         reliability 255/255, txload 1/255, rxload 1/255
      Keepalive set (10 sec)
      Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
      input flow-control is off, output flow-control is off
      Auto-MDIX on (operational: on)
      ARP type: ARPA, ARP Timeout 04:00:00
      Last input 2d09h, output never, output hang never
      Last clearing of "show interface" counters never
      Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
      Queueing strategy: fifo
      Output queue: 0/40 (size/max)
      5 minute input rate 0 bits/sec, 0 packets/sec
      5 minute output rate 0 bits/sec, 0 packets/sec
    the other port of the controller works fine as usual
    (UAM-CLCAR-MB02MDF-WC01) (config) #show interface gigabitethernet 0/0/0
    GE 0/0/0 is up, line protocol is up
    Hardware is Gigabit Ethernet, address is 00:1A:1E:02:29:C1 (bia 00:1A:1E:02:29:C1)
    Description: UNI_CH_CARR2_CAT_13 port 2/16 (RJ45 Connector)
    Negotiated: Duplex (Full), speed (1000 Mbps)
    MTU 1500 bytes, BW is 1000 Mbit
    Last clearing of "show interface" counters 3 day 8 hr 20 min 57 sec
    link status last changed 3 day 8 hr 17 min 43 sec
    192898313 packets input, 140627488641 bytes
    Received 11496220 broadcasts, 0 runts, 0 giants, 0 throttles
    5989444 multicast, 181402093 unicast
    173427704 packets output, 142666827992 bytes
    un-ula-chlcar2-csw001#show interfaces gigabitEthernet 1/10
    GigabitEthernet1/10 is up, line protocol is up (connected)
    Hardware is Gigabit Ethernet Port, address is a03d.6fc1.7029 (bia a03d.6fc1.7029)
    Last input 00:00:08, output never, output hang never
    5 minute input rate 4117000 bits/sec, 558 packets/sec
    5 minute output rate 4056000 bits/sec, 593 packets/sec
    173400473 packets input, 142647562690 bytes, 0 no buffer
    Received 1265297 broadcasts (594044 multicasts)
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
    0 input packets with dribble condition detected
    192867573 packets output, 140607784942 bytes, 0 underruns
    0 output errors, 0 collisions, 3 interface resets
    any help would be appreciated
  • 2.  RE: controller port is not negotiating duplex and speed
    Posted Jan 22, 2020 03:42 AM
    Can you confirm the physical connectivity again? Port description on the controllers says 2/17 and the output you have provided is 2/10.
    Also, can you share port configs from both sides?
  • 3.  RE: controller port is not negotiating duplex and speed
    Posted Jan 22, 2020 03:45 AM
    please ignore the description on the port it is incorrect and a typo, i will share the port configuration from both sides.
  • 4.  RE: controller port is not negotiating duplex and speed
    MVP EXPERT
    Posted Jan 22, 2020 09:14 AM
    As a test, have you tried hard setting the duplex and speed to see if the port comes up?
  • 5.  RE: controller port is not negotiating duplex and speed
    Posted Jan 22, 2020 09:43 AM
    i have tried that on the switch side to set the speed and duplex as manual and bounced the port , still no luck.
    on the aruba controller i havent tried that yet, as i will have to take the port out of port-channel and then set the speed and duplex manually , if i do that will there be any impact on the network , i guess not , right ?
  • 6.  RE: controller port is not negotiating duplex and speed
    MVP EXPERT
    Posted Jan 22, 2020 09:46 AM
    There shouldn’t be providing your port channel is working as expected and there is still an interface in the port channel group :)
