Controller Radio Parameter EIRP 127
  • 1.  Controller Radio Parameter EIRP 127
    Posted 26 days ago
    HI All
    As per below screen shot in AP group profile we can set Min and Max EIRP value to 127. EIRP 3 to 33 is normal range. I need understanding on EIRP value 127. When and Which scenario to use EIRP value 127.
  • 2.  RE: Controller Radio Parameter EIRP 127
    Posted 26 days ago
    Setting the max to 127 allows the maximum power on the AP, which is a different value for the various AP models.  Useful when you don't have a specific maximum power that you want to use.
    Carson Hulcher, ACEX#110
