Controller Radio Parameter EIRP 127
  • 1.  Controller Radio Parameter EIRP 127
    Posted Jun 06, 2024 06:05 AM
    HI All
    As per below screen shot in AP group profile we can set Min and Max EIRP value to 127. EIRP 3 to 33 is normal range. I need understanding on EIRP value 127. When and Which scenario to use EIRP value 127.
  • 2.  RE: Controller Radio Parameter EIRP 127
    Posted Jun 06, 2024 10:04 AM
    Setting the max to 127 allows the maximum power on the AP, which is a different value for the various AP models.  Useful when you don't have a specific maximum power that you want to use.
    Carson Hulcher, ACEX#110
