Well – it’s a big rollout so you should reach out to HPE Aruba for assistance or be pointed to a partner that has done this before. That will give you a kickass network without all the headache if learning as you go – the hard way 😉
If you’ve already decided that Aruba is the way to go (smart choice!) you could and should read up on the Aruba VRD’s (Validated Reference Design Guides) and learn about Best Practices and how the technology functions.
AOS 8 with a virtual MM and 2 Hardware 7220 Controllers is what you want for your 500 AP’s. You should also look into your current infrastructure to validate that you have the right switches for the job – think PoE+ for all AP’s. Realise that no client traffic is bridged locally – so ALL client traffic is tunnelled back to the controller.
What about monitoring? MM/Controllers only give you current status. You might need a tool like Aruba Airwave to monitor it all to make sure you can go back in time to troubleshoot, see where your RF issues are or just get reports of usage over time.
Authentication? Do you know your network well enough and/or have a great AAA server that is easy to work with and gives your full control of what gets online on your wireless? IF not – then you might want Aruba Clearpass! Be caerful tho – once you try it you can’t go back 😉
I could go on and on, but you know – reach out to your local HPE Aruba office and get a proper introduction to the technology.
Cheers and good luck!
John
