Controller Running 8.6 code
This thread has been viewed 22 times
  • 1.  Controller Running 8.6 code
    Posted 13 days ago
    I have 2 controllers with 8.6 code that I need to join to a Mobility Conductor running 8.10.  Is this possible?  I know you can have the controllers running a lower code than Mobility Conductor.  The controllers are remote, so I do not have the ability to upgrade them to 8.10 until they are joined to the Mobility Conductor.  Please advise.
    Peter
  • 2.  RE: Controller Running 8.6 code
    Posted 12 days ago
    the feature is called multi-version and i think it should be fine.
    Here is the user guide reference for Mobility conductor with 8.10.
  • 3.  RE: Controller Running 8.6 code
    Posted 12 days ago
    Thank you!
    Peter
  • 4.  RE: Controller Running 8.6 code
    Posted 12 days ago
    There may be a logged warning about version mismatch but the association should go fine.  8.10 on a Conductor is specifically called out as having multi-version support down to MDs running 8.6.
    Carson Hulcher, ACEX#110
  • 5.  RE: Controller Running 8.6 code
    MVP EXPERT
    Posted 11 days ago
    I migrate some customers from 8.6.x.x to 8.10.x.x without any issues.
    • First update the Mobility Conductor
    • Second update your Managed Devices (gateways).
    Create VMware snapshot and configuration of the Mobility Conductor before you start.
    Marcel Koedijk | MVP Expert 2023 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
