Mobility Express and Aruba Instant are completely different solutions and brands.
You started with that you have Aruba Instant, and the answers are for Aruba Instant. Following the Validated Reference Device Guide, you should not make any of the APs 'preferred primary', but let the system handle it. That is regardless what other solutions may have as a best-practice, I would follow the Aruba best-practice if you have Aruba.
Also, if your APs go down regularly with power issues, I would investigate the reason for that and address/fix that.
Original Message:
Sent: Dec 07, 2022 01:15 PM
Subject: Controller takeover kills SSIDS being broadcasted from ex-Controller
thanks for refrencing document. i will give it a more thorough reading. but i need to confirm if above behaviour is normal ?
my understanding form cisco is that the ap which was set manually to be master controller upone snatching its role from the so elected primary after it failyr doestn affects the users on the ex-primary .that ap seamlessly returns the role of the master controller and doesnt affects users connected to it neither does it restarts.
i am talking of cisco mobility express
Original Message:
Sent: Dec 07, 2022 03:43 AM
Here is the validated design guide for Instant APs
https://community.arubanetworks.com/browse/articles/blogviewer?BlogKey=1f47bc48-dafb-4b48-9ff1-2973bb3c2f87
Original Message:
Sent: Dec 07, 2022 03:23 AM
The best advice is not to use preferred controller option and leave it default. As you have all APs of the same type it is of no importance who is Virtual Controller.
If you have dedicated VC, then migration will start as soon as dedicated VC join the cluster.
You can have some benefits from dedicated VC when you have very small APs in the cluster and really don't won't any of them to assume VC role.
Best, Gorazd
Gorazd Kikelj
Original Message:
Sent: Dec 06, 2022 04:40 AM
I am having an issue with Aruba Instant AP 505 based deployement.
I have 7 505 APS. 3 on one floor and 5 on other. its new deployment and one AP on floor 1 of 4 is primary. on second day of its deployment all aps on the floor having primary controller went down due to power issue, then one of the 3 remaining aps on other floor took the role of primary when the power was restored on the first floor and all 4 aps were powered up the ap which we manually had set as primary again snatched the primary role. during this snatching the ap that was priamary controller went down .(no ping ) and at that exact location the SSIDs broadcasted by it also went down and it came back after 3-4 minutes.
i simulated above scenario again and noted same thing.
Please someone advise why is this happening this is is affecting users and will cause a lot of trouble in our environment as we have live calls and meetings going on .
Regards
