Controller taking a lot of memory
  • 1.  Controller taking a lot of memory
    Posted Feb 10, 2014 09:25 AM
    Good day, Should I be concerned about 95% memory on my controller sound very high.
    Controller model is Aruba3200 running AOS 6.1.3.7 acting as a Master controller.
     #  show mem
    Memory (Kb): total: 354060, used: 339800, free: 14260
  • 2.  RE: Controller taking a lot of memory
    Posted Feb 10, 2014 09:49 AM
    I'd recommend you upgrade your 3200 with the XM memory module (3200-MEM-UG).  This will bring the memory up to 1GB for the 3200.  With 6.1, a 3200 without the memory will be heavily loaded.  Also, without it, you cannot run 6.2 or higher code.
  • 3.  RE: Controller taking a lot of memory
    Posted Feb 10, 2014 11:23 AM
    Okay, But Should I be worried about the status of the controller?
  • 4.  RE: Controller taking a lot of memory
    Posted Feb 10, 2014 11:34 AM
    Yes, I would be concerned and definitely upgrade the memory (or controller).    From an engineering perspective, anything less than 10MB free on the 3200 would be considered critical.
  • 5.  RE: Controller taking a lot of memory
    Posted Feb 11, 2014 08:36 AM
    Edgardo, if the upgrade is not done what you will see is that your controller will suddenly stop responding and require a manual reboot to clear the memory.
    We suffered this and upgraded the memory and the headache was gone.
