Controller totally blocked
  • 1.  Controller totally blocked
    Posted Mar 05, 2013 09:02 AM
    I have tried to upgrade my Aruba 3200 controller to a new version and now it is completely blocked. I can't access it by IP, the only way is by the serial port.
    When I want to login, my password isn't valid any more (I am sure of it). Support gave me a procedure to reset it and erase the configuration of the controller.
    But when I try the procedure, I can't change the password. Every time I get the message "Error : Non-Compliant to Mgmt Password Policy Internal error occurred, Password validation failed". I am sure that no policy was configured and I can enter every possible password and still the same error.
    Any idea to solve this ? No problem to get back "out of the bock", the controller is in the lab.
    Dimitri
    #3200
  • 2.  RE: Controller totally blocked
    Posted Mar 05, 2013 09:21 AM
    Hi
    Here you go:
    Here is an example how to reset admin/enable password: *VIA CLI CONSOLE- SERIAL PORT - ONLY*
    User: password
    Password: forgetme!
    (aruba) >enable
    Password: enable
    (aruba) #configure terminal
    Enter Configuration commands, one per line. End with CNTL/Z
    (aruba) (config) #mgmt-user admin root
    Password:
    Re-Type password:
    (aruba) (config) #exit
    (aruba) #exit
    (aruba) >exit
    User: admin
    Password:
    (aruba) >enable
    Password: enable
    (aruba) (config) #enable secret
    Password:
    Re-Type password:
    (aruba) (config) #write memory
    It will give u the ability to reset password via serial port.
    have a nice day.
    *after you will reset you pass/user - you will be able to run show interfaces... or change/delete the config.
    me
  • 3.  RE: Controller totally blocked
    Posted Mar 05, 2013 09:24 AM
    Thanks but my problem is at this point :
    Password:
    Re-Type password:
    I can't change the password. Here is the error message I have : Error : Non-Compliant to Mgmt Password Policy Internal error occurred, Password validation failed.
    The point is that I haven't configure any password policy.
    Dimitri
  • 4.  RE: Controller totally blocked
    Posted Mar 05, 2013 09:32 AM
    Try do do a longerpassword - for the test try:
    Aruba4ever
  • 5.  RE: Controller totally blocked
    Posted Mar 05, 2013 09:36 AM
    Tried, same issue even with a much more longer password.
    Dimitri
  • 6.  RE: Controller totally blocked
    Posted Mar 05, 2013 10:04 AM
    Very Very wired - did u contact Aruba TAC regarding this issue?
  • 7.  RE: Controller totally blocked
    Posted Mar 05, 2013 10:05 AM
    Yes, at this time, they gave me the same procedure as you. Waiting for news...
    Dimitri
  • 8.  RE: Controller totally blocked
    Posted Mar 05, 2013 10:09 AM
    Dont wait for news.
    start to try all the options: (u dont have nothing to lose)  *say thanks to jfernyc*
    You need a password that is compliant with the management password
    policy as configured on the controller.
    There are several parameters that can be set (and clearly are in your
    case/controller), per below:
    Enable password policy
    Set minimum password length (6-32 characters)
    Set/config minimum upper case characters required for passwd (0-10)
    Set/config minimum lower case characters required for passwd (0-10)
    Set/config minimum special case characters required for passwd (0-10)
    Set/config the number of numerical digits required for passwd (0-10)
    Set/config the # of times a single character can be repeated in a passwd
    (0-10)
    Deny the use of a known username, or the reverse of a username in a
    passwd
    If you can find out which of these are set you can then select a
    compliant password.
    BTW:
    are u using FIPS or upgraded to FIPS? if so --> the following post - will solve your issue:
    http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/locked-out-after-FIPS-upgrade/td-p/35541
    Have a lovley day.
    me
  • 9.  RE: Controller totally blocked
    Posted Mar 05, 2013 10:14 AM
    Thanks I will follow the post and try to solve this issue.
    Dimitri
  • 10.  RE: Controller totally blocked
    Posted Mar 05, 2013 10:21 AM
    tell me if it worked for u :smileywink:
  • 11.  RE: Controller totally blocked
    Posted Mar 05, 2013 10:29 AM
    The thing is that I can only enter a username and password in the CLI. I don't now how to get in cpboot mode.
    Dimitri
  • 12.  RE: Controller totally blocked
    Posted Mar 05, 2013 10:35 AM
    cpboot mode:
    just reboot your controller. (while you console cable is connected and putty/securecrt are running)
    and stop the controller few sec before he boots (you will see a counter saying 1-2-3-4 press enter to stop boot process..)
  • 13.  RE: Controller totally blocked
    Posted Mar 05, 2013 11:09 PM
    Dimitri
    Cpboot mode is ONLY to be used when there is a serious problem booting the controller code.  Did you enter enable mode after you put in the username and password?
  • 14.  RE: Controller totally blocked
    Posted Mar 06, 2013 02:34 AM
    Yes I did.
  • 15.  RE: Controller totally blocked
    Posted Mar 06, 2013 05:13 AM
    Okay, so you can get into the controller.  What is wrong?
  • 16.  RE: Controller totally blocked
    Posted Mar 06, 2013 06:06 AM
    I can't connect to the controller with its IP address and with the serial port, I can't make any changes because my username and password are not reconnized.
    If I follow the procedure given in the last posts, I can't change the email of the admin. I get this error message : Error : Non-Compliant to Mgmt Password Policy Internal error occurred, Password validation failed. But no Policy was configured.
    Dimitri
  • 17.  RE: Controller totally blocked
    Posted Mar 06, 2013 06:21 AM
    The password should by default have more than 6 characters.  I am assuming you already tried that...
    Did you try creating a root user besides admin?
  • 18.  RE: Controller totally blocked
    Posted Mar 06, 2013 06:23 AM
    No I haven't try this.
    And yes, I have tried password of 6 and more characters.
    Dimitri
  • 19.  RE: Controller totally blocked
    Posted Mar 08, 2013 02:40 AM
    I want a step further.
    Now I can configure the controller by the console but when I save it, it loops back to the Aruba 3200 setup dialog.
    I can read this before the dialog setup :
    Saving current config file default.cfg as default...
    Generating new configuration
    Configuration upgrade complete
    Reading configuration from factory-default.cfg
    Starting FIPS Aruba Cryptographic KAT test
    But after, I am back to setup dialog and if I try again to configure it, still the setup dialog.
    Any idea ?
    Dimitri
  • 20.  RE: Controller totally blocked
    Posted Mar 08, 2013 04:04 AM
    Last Step:
    boot into cpboot and do this:
    setenv cfgfile
    save
    boot
  • 21.  RE: Controller totally blocked
    Posted Mar 08, 2013 04:56 AM
    I works with your last step. Now it reboots on the controller and I can login with username and password.
    Dimitri
  • 22.  RE: Controller totally blocked
    Posted Mar 08, 2013 07:11 AM
    So now the controller is as out-of-the-box but I can't access to the webUI. The controller is not connected to the network, I have setup my IP address to 172.16.0.99 and connected directly to the controller.
    But when entering 172.16.0.254, nothing happends. I can't go the webUI but if I open a terminal, I can see the setup dial ?
    Any idea ?
    Dimitri
  • 23.  RE: Controller totally blocked
    Posted Mar 11, 2013 03:03 AM
    Problem solved with the help of support. It was about DHCP issue and FIPS update.
    Edit : I have talked a bit too fast. A new issue has appeared, when using the webUI, the configuration doesn't save. Everytime, I am back to the basic config. It's like that nothing was saved.
    Someone knows where the problem come from ?
    Thanks for your help.
    Dimitri
  • 24.  RE: Controller totally blocked
    Posted Feb 16, 2015 10:04 PM
    I have 2 brand new 7210 controllers and the exact same issue - cannot use the password I configured in the setup dialogue and cannot do a password recovery due to password policy.
    Can anyone assist?
    #7210
  • 25.  RE: Controller totally blocked
    Posted Feb 16, 2015 10:15 PM
    Please contact TAC.
  • 26.  RE: Controller totally blocked
    Posted Feb 18, 2015 08:48 PM
    For the next person with this issue, it seems to a bug with choosing the 'Disable all interfaces' option in the setup dialogue. Everything works fine if you don't choose that option.
  • 27.  RE: Controller totally blocked
    Posted May 06, 2015 02:22 AM
    Has this been resolved? Im having the same problem with a dell branded controler. Ive ran through the setup wizard a few times with different options with no luck. I can't reset the password with the password:forgetme! username and combination either. This is the second of 2 identical controllers im configuring only difference this is a "local" not "master"
    User: password
    Password: *********
    (Dell PowerConnect W-7210 Controller) >en
    Password:******
    (Dell PowerConnect W-7210 Controller) #configure t
    (Dell PowerConnect W-7210 Controller) (config) #mgmt-user admin root
    Password:***********
    Re-Type password:***********
  • 28.  RE: Controller totally blocked
    Posted May 06, 2015 06:59 AM
    RichardG,
    What version of Dell OS did it come with and what options did you choose for your steps?
  • 29.  RE: Controller totally blocked
    Posted May 07, 2015 01:04 AM
    It shipped with ArubaOS 6.3.1.5 (build 43118 / lable #43118)
    The options I selected:
    Enter System Name: xxxxxxxx.xxxxx
    Enter Switch Role: local
    Enter Master Switch IP address: 172.17.x.5
    Enter Master Switch Mac address: xx:xx:xx:xx:xx:xx
    Enter Redundant master switch mac: <none>
    VLAN 1 interface IP address: 172.17.x.6
    VLAN 1 interface subnet mask: 255.255.255.0
    IP Default Gateway: 172.17.x.1
    Country Code: AU
    Timezone: <none (wouldnt let me enter UTC+10)>
    Enter time in UTC: 05:16:30
    Enter Date: 05/06/2015
    Enter password for admin: xxxxxxxxxxxx
    Re-type password for admin: xxxxxxxxxxxx
    Enter password for enable: xxxxxxxxxxxx
    Re-type password for enable: xxxxxxxxxxxx
    Do you wish to shutdown all the ports: yes
    I entered both the admin and enable passwords as the same. This config didnt work so i wiped the config and chose not to shutdown the ports with the same outcome. Both times i tried to go down the password restore path with no luck (all different passwords tried, short, long, complex, simple)
    Error: Non-Compliant to Mgmt Password Policy
    im thinking it could have something to do with local vs master? I didnt have trouble with the other controller I got which is identical.
  • 30.  RE: Controller totally blocked
    Posted May 07, 2015 01:12 AM
    How did you wipe the config?
  • 31.  RE: Controller totally blocked
    Posted May 07, 2015 02:31 AM
    To clear the configuration
    cpboot> setenv cfgfile 1
    cpboot> save
    cpboot> reset
    I reset instead of doing bootaos because for some reason that wouldn't work
    After I ran the wizard again I did the following
    cpboot> save
    cpboot> reset
  • 32.  RE: Controller totally blocked
    Posted May 07, 2015 04:30 AM
    Looking at my logs I also selected master the first time along with shutdown all interfaces.
    Then wiped the config, chose local and do not shutdown interfaces to get it working.
  • 33.  RE: Controller totally blocked
    Posted May 07, 2015 06:08 AM
    BGC IT,
    Did you have a case# for your issue?  If so, please PM me so we can see how far it has progressed.
  • 34.  RE: Controller totally blocked
    Posted May 07, 2015 09:17 PM
    Hi CJ, No case for this.
  • 35.  RE: Controller totally blocked
    Posted May 10, 2015 07:03 AM
     I was able to get past the issue I was having by setting up my second controller as a master, then converting it after initial setup. :) thanks for all the help!
    Richard
  • 36.  RE: Controller totally blocked
    Posted Jun 24, 2018 12:16 PM
    I agree that this process definitely works.  I have added some small text differences as of 6/2018 on firmware 6.5.
    I found that running the "minimal-setup" on bootup will get you stuck vs "full-setup".  I am not running the FIPS version of the firmware which is mentioned in many articles.
     "Non-compliant to management password policy"
    Hit any key to stop autoboot:  0
    cpboot>
    cpboot> setenv cfgfile default1.cfg
    cpboot> saveenv
    cpboot> bootf
    After I ran the wizard and rebooted, I had to go into cpboot again and change the cfgfile back.
    cpboot>
    cpboot> saveenv
    Saving Environment to Flash...
    cpboot>bootf
  • 37.  RE: Controller totally blocked
    Posted May 06, 2015 08:31 PM
    CJ, for me it happened on 6.4.2.3 but it's clearly been around for a while.
    Richard, do repair this you need to do the CPboot thing described earlier in the thread to get back to a default state, then redo the install without disabling interfaces.
