Controller Typs Redundandency
  • 1.  Controller Typs Redundandency
    Posted Jan 09, 2015 07:20 AM
    Hello, is it possible to Mix Controller Platforms in a Master-Master Redundandency, or is it necessary to use the same Model.
    Thanks and Regards Mirko
  • 2.  RE: Controller Typs Redundandency
    Posted Jan 09, 2015 07:26 AM
    You can mix it up but have to keep in mind the amount of APs / Clients supported on each platform and make sure that when APs failover the redundant controller is able to support these.
    What models are you using ?
  • 3.  RE: Controller Typs Redundandency
    Posted Jan 09, 2015 07:28 AM
    3200 and 7010
  • 4.  RE: Controller Typs Redundandency
    Posted Jan 09, 2015 07:44 AM
    I not 100% sure but I think is not recommended to use 7005/7010 as master controllers
  • 5.  RE: Controller Typs Redundandency
    Posted Jan 09, 2015 10:52 AM
    I wouldn't mix platforms with different internal architecture which will have different roadmaps for software and hardware
