Controller vs the CLI
  • 1.  Controller vs the CLI
    Posted Aug 15, 2019 11:26 AM
    Hi All,
    I have a strange one that i cannot fiugre out.
    I have a Aruba7210 controller. When i look in the controller Dashboard -> Clients  it show all the connect clients, but it also shows some clients that are not connected, they have no IP address are in the correct Role etc.
    If i run a show user-table they do not appear
    I can only get them to not appear in the GUI if i reboot the controller
    Adam
  • 2.  RE: Controller vs the CLI
    Posted Aug 19, 2019 07:12 PM
    Perhaps it’s a UI bug or browser issue. See if incognito mode helps otherwise see if you can upgrade to the latest maintenance version of the controller OS version.
