Controller with Port 4500 and RAPs
This thread has been viewed 34 times
  • 1.  Controller with Port 4500 and RAPs
    Posted Jan 11, 2021 10:17 AM
    I have some question here
    1-Remote site have 10 AP at each site – customer need to use remote solution and port 4500 is blocked at main site which solution is better ( Branch Controller – RAP – IAP VPN – VIA ) ?
    2-Three remote sites connecting as RAP to main site with single Controller behind Firewall with NAT
    Customer need to add 2 another controller what is the recommended solution for redundancy
    • Make cluster and assign one public IP and 3 Private IP and make NAT over 4501-4502-4503 port
    • Purchase two new public IP address
    • Purchase two new Public IP address and remove NAT over firewall
    n/a
  • 2.  RE: Controller with Port 4500 and RAPs
    Posted Jan 13, 2021 04:03 AM
    no one here :D ?
    amr shawky
  • 3.  RE: Controller with Port 4500 and RAPs
    Posted Jan 14, 2021 05:02 AM
    RAP (and VIA, and IAP-VPN) will only work over port 4500/udp.
    When using AOS8 clustering, you will need to have a public IP for each of the controllers that participate in the cluster that offers the VPN services for RAP/VIA/IAP-VPN. Most common is to NAT on the firewall as it saves IP addresses when public IPs are pulled from a larger block on the firewall, versus putting a public subnet for the controllers that need a network and broadcast address, one IP for the firewall/router and you need to slice a subnet of 4, 8,16 IPs (effective 1, 5, 13 hosts outside your firewall/router). As well, with NAT you can just port-forward port 4500/udp for the controller, and use other ports for other services.
    An alternative would be to use the legacy HA, with VRRP, in which case you can have a NAT to the VRRP address of your controllers. This doesn't have the load-balancing active-active behavior like with Clustering, but if one controller can handle all the load/APs, it is an option if getting additional public IP is hard or expensive I think it is a solid option. For increased availability, you can use a backup LMS VRRP in a different datacenter.
    Your Aruba partner should be able to advise in your specific situation; or your local Aruba team if you work for a partner.
  • 4.  RE: Controller with Port 4500 and RAPs
    Posted Feb 05, 2021 09:08 AM
    Thanks Herman ,
    Please find below comments
    RAP (and VIA, and IAP-VPN) will only work over port 4500/udp.  One of them must work without udp4500
    So this is a question so must have a correct one answer
    ( A#Branch Controller – B#RAP – C#IAP VPN – D#VIA ) So this is the chosse A,B,C,and D must chsse one of them
    for second question i have written , it is aquestion with one valid answer it is not design proposal , so i think for your answer tat the correct aswer would be B -- right
    amr shawky
