Network Management
Controller/Airwave Audit-trail Logins
  • 1.  Controller/Airwave Audit-trail Logins
    Posted Nov 05, 2013 09:11 AM
    I'm looking to generate a report from Airwave or a trigger option to collect administrative logins to the Airwave server as well as to the Controller. Is this possible using Airwave or direct from the controller?
    I can run #show audit-trail login manually but would prefer an automated solution especially since I can only use a single output modifier from CLI.
  • 2.  RE: Controller/Airwave Audit-trail Logins
    Posted Nov 05, 2013 11:02 AM
    You can potentially use this :
    2013-11-05 10_50_38-__129.64.8.73_c$_Users_vfabian_Desktop_2013-11-04 10_22_40-Edit scheduled activi.png
  • 3.  RE: Controller/Airwave Audit-trail Logins
    Posted Nov 06, 2013 12:38 PM
    This pointed me a good direction for the controller. Do you know of a similar command on the airwave CLI that would get me info for the GUI? I'm sure I can pull CLI info from a log file somewhere.
  • 4.  RE: Controller/Airwave Audit-trail Logins
    Posted Nov 06, 2013 01:17 PM
    I don't see this available on the list of commands you can run from AIrwave
    I can't see it from the trap list either
    SNMP TRAP LIST
    TRAP-NAME                                  CONFIGURABLE  ENABLE-STATE
    authenticationFailure                      Yes           Enabled
    coldStart                                  Yes           Enabled
    linkDown                                   Yes           Enabled
    linkUp                                     Yes           Enabled
    warmStart                                  Yes           Enabled
    wlsxAPBssidEntryChanged                    Yes           Enabled
    wlsxAPChannelChange                        Yes           Enabled
    wlsxAPDeauthContainment                    Yes           Enabled
    wlsxAPEntryChanged                         Yes           Enabled
    wlsxAPImpersonation                        Yes           Enabled
    wlsxAPInterferenceCleared                  Yes           Enabled
    wlsxAPInterferenceDetected                 Yes           Enabled
    wlsxAPModeChange                           Yes           Enabled
    wlsxAPNumColdStarts                        Yes           Enabled
    wlsxAPNumDown                              Yes           Enabled
    wlsxAPNumRadioDown                         Yes           Enabled
    wlsxAPNumUpgradeFailure                    Yes           Enabled
    wlsxAPNumWarmStarts                        Yes           Enabled
    wlsxAPPowerChange                          Yes           Enabled
    wlsxAPRadioAttributesChanged               Yes           Enabled
    wlsxAPRadioEntryChanged                    Yes           Enabled
    wlsxAPSpoofingDetected                     Yes           Enabled
    wlsxAPTaggedWiredContainment               Yes           Enabled
    wlsxAPWiredContainment                     Yes           Enabled
    wlsxAccessPointIsDown                      Yes           Enabled
    wlsxAccessPointIsUp                        Yes           Enabled
    wlsxAdhocNetwork                           Yes           Enabled
    wlsxAdhocNetworkBridgeDetected             Yes           Enabled
    wlsxAdhocNetworkBridgeDetectedAP           Yes           Enabled
    wlsxAdhocNetworkBridgeDetectedSta          Yes           Enabled
    wlsxAdhocNetworkDetected                   Yes           Enabled
    wlsxAdhocNetworkRemoved                    Yes           Enabled
    wlsxAdhocUsingValidSSID                    Yes           Enabled
    wlsxApFloodAttack                          Yes           Enabled
    wlsxAuthMaxAclEntries                      Yes           Enabled
    wlsxAuthMaxBWContracts                     Yes           Enabled
    wlsxAuthMaxUserEntries                     Yes           Enabled
    wlsxAuthServerIsUp                         Yes           Enabled
    wlsxAuthServerReqTimedOut                  Yes           Enabled
    wlsxAuthServerTimedOut                     Yes           Enabled
    wlsxBSSIDIsDown                            Yes           Enabled
    wlsxBSSIDIsUp                              Yes           Enabled
    wlsxBlockAckAttackDetected                 Yes           Enabled
    This could be a feature request :
    https://arubanetworkskb.secure.force.com/cp/ideas/ideaList.apexp
  • 5.  RE: Controller/Airwave Audit-trail Logins
    Posted Nov 05, 2013 11:05 AM
    Are you using TACACS? (ClearPass)
    TACACS accounting will log all commands if configured:
