  • 1.  Controlller aruba 7210 refuses to access .web browser gives error
    Posted Mar 06, 2024 11:33 AM
    Controlller aruba 7210 refuses to access .web browser gives error,What do I need to do about it Os currently it is 6.5.
    Has anyone encountered a similar situation?
    please give me solution
    (Aruba7210) #show version
    ArubaOS (MODEL: Aruba7210-US), Version 6.5.1.4
    Website: http://www.arubanetworks.com
    (c) Copyright 2016 Hewlett Packard Enterprise Development LP.
    Compiled on 2017-03-10 at 07:38:38 UTC (build 58698) by p4build
    Hmmm… can't reach this page
    It looks like the webpage at https://192.168.1.244:4343/ might be having issues, or it may have moved permanently to a new web address.
    ERR_SSL_KEY_USAGE_INCOMPATIBLE
  • 2.  RE: Controlller aruba 7210 refuses to access .web browser gives error
    Posted Mar 06, 2024 12:14 PM
    OS 6.5 is out of date and unsupported.
    More specifically, is using a globally unsupported TLS Version - which is the root of your issue.
    I would highly suggest a major firmware upgrade - which would likely need to be multi stepped.
    Else, you would need to allow your browser usage of unsupported TLS versions - and add an exception for that certificate.
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 3.  RE: Controlller aruba 7210 refuses to access .web browser gives error
    Posted Jul 24, 2024 08:25 AM
    Thanks for this reply. I was also getting this error on all chromium browsers [Edge / Chrome / Brave] on our 7205 running 8.6.0.23 so I upgraded our controller to the latest LSR 8.10.0.13. Unfortunately the error still exists on this version as well. Is there a known workaround on 8.10.x by chance? Firefox is the only browser that works in my testing.
