Convert a RAP to IAP
This thread has been viewed 32 times
  • 1.  Convert a RAP to IAP
    Posted Apr 29, 2020 03:43 PM
    Hello all,
    I am working remotely and I have a RAP 303 that terminate at the controller. I also have access to airwave.
    we are transitioning from RAP deployment to IAP-VPN.
    how can I convert the RAP to IAP remotely so I can configure it be as a Master instant AP and the others at the same location as Slave instant APs.
    Thanks!
  • 2.  RE: Convert a RAP to IAP
    MVP GURU
    Posted Apr 29, 2020 04:48 PM
    Oh that's going to be tough. I think you should be able to enable ap telnet/ssh, and then wipe the configuration from the remote console connection. You should then point the APs to Airwave via Aruba Activate and then push a config, or use Aruba Central if you have it to configure the AP for IAP-VPN.
    Otherwise someone will have to console into the AP and factory reset it....
  • 3.  RE: Convert a RAP to IAP
  • 4.  RE: Convert a RAP to IAP
    MVP GURU
    Posted Apr 29, 2020 04:51 PM
    Oh that's awesome! That's going in the reference notebook
  • 5.  RE: Convert a RAP to IAP
    Posted Apr 29, 2020 05:06 PM
    That is awesome! I will definitely try it once the transition starts.
    Thanks again!
  • 6.  RE: Convert a RAP to IAP
    Posted Dec 05, 2023 10:42 AM
    Hello, this link doesn't seem to be valid anymore, greatly appreciate if anyone can share the link to the article.
  • 7.  RE: Convert a RAP to IAP
    Posted Dec 05, 2023 03:47 PM
    The web help has a section on converting APs to Instant APs. https://www.arubanetworks.com/techdocs/ArubaOS_8.11.0_Web_Help/Content/arubaos-solutions/access-points/conv-ap-iap.htm
    Josh
