convert ap-225 to standalone
  • 1.  convert ap-225 to standalone
    Posted Feb 17, 2016 06:33 AM
    hi,
    I use AP-225.  I wanted to convert to standalone mode.  So, I followed the link below:
    http://community.arubanetworks.com/t5/Controller-less-WLANs/How-do-I-convert-an-IAP-to-standalone-using-the-CLI/ta-p/180934
    Even after giving the following commands
    apboot> setenv standalone_mode 1
    apboot> save
    apboot>load
    APBoot 1.5.4.10 (build 50639)
    Built: 2015-06-29 at 12:15:54
    Model: AP-22x
    CPU0:  P1020E, Version: 1.1, (0x80ec0011)
    Core:  E500, Version: 5.1, (0x80212051)
    Clock:
           CPU0: 800 MHz
           CPU1: 800 MHz
           CCB:  400 MHz
           DDR:  333.333 MHz (666.667 MT/s data rate) (Asynchronous)
           LBC:   25 MHz
    L1:    D-cache 32KB enabled
           I-cache 32KB enabled
    I2C:   ready
    DRAM:  Configuring DDR for 666.667 MT/s data rate
    DDR:   512 MB (DDR3, 32-bit, CL=5, ECC off)
    POST1: memory passed
    Flash: 32 MB
    L2:    256 KB enabled
    Power: 802.3af POE
    PCIe1: RC, link up, x1
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  14e4  43a2 00002   03 80000004 00000000 80200004 00000000
    PCIe2: RC, link up, x1
           00  00  14e4  43a1 00002   03 a0000004 00000000 a0200004 00000000
    Net:   eth0, eth1
    Radio: bcm43460#0, bcm43460#1
    FIPS: passed
    Hit <Enter> to stop autoboot:  0
    apboot>
    apboot>
    apboot>
    apboot>
    apboot>
    apboot>
    apboot> save
    Saving Environment to Flash...
    Un-Protected 1 sectors
    . done
    Erased 1 sectors
    Writing 9....8....7....6....5....4....3....2....1....
    apboot> printenv
    bootdelay=2
    baudrate=9600
    autoload=n
    boardname=Ardmore
    servername=aruba-master
    bootcmd=boot ap
    autostart=yes
    bootfile=e500.ari
    ethaddr=04:bd:88:cd:28:be
    stdin=serial
    stdout=serial
    stderr=serial
    ethact=eth0
    standalone_mode=1
    Environment size: 224/131068 bytes
    apboot> boot
    Checking image @ 0xee000000
    Invalid image format version: 0xffffffff
    Checking image @ 0xeee00000
    Copying image from 0xeee00000
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Aruba Networks
    ArubaOS Version 6.3.1.0 (build 39345 / label #39345)
    Built by p4build@tortuga on 2013-08-08 at 16:30:24 PDT (gcc version 4.5.1)
    Memory: 510348k/524288k available (8348k kernel code, 13940k reserved, 540k data
    , 352k bss, 5008k init)
    Processor 1 found.
    Brought up 2 CPUs
    PCI: Probing PCI hardware
    pci 0000:00:00.0: PCI bridge to [bus 01-ff]
    pci 0001:02:00.0: PCI bridge to [bus 03-ff]
    pci 0000:00:00.0: enabling device (0106 -> 0107)
    pci 0001:02:00.0: enabling device (0106 -> 0107)
    ee000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank
    Amd/Fujitsu Extended Query Table at 0x0040
    number of CFI chips: 1
    /proc/gfar_eth0_stats created
    /proc/gfar_eth1_stats created
    Enabling watchdog on CPU 1
    Enabling watchdog on CPU 0
    Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    Starting Kernel DES KAT ...Completed Kernel DES KAT
    Starting Kernel AES KAT ...Completed Kernel AES KAT
    Domain Name: arubanetworks.com
    No panic info available
    Ethernet port 1 mode: active-standby
    ADDRCONF(NETDEV_UP): eth0: link is not ready
    ADDRCONF(NETDEV_UP): bond0: link is not ready
    bonding: bond0: enslaving eth0 as a backup interface with a down link.
    ADDRCONF(NETDEV_UP): eth1: link is not ready
    bonding: bond0: enslaving eth1 as a backup interface with a down link.
    AP xml model 66, num_radios 2 (jiffies 3213)
    init_asap_mod: installation:0
    radio 0: band 1 ant 0 max_ssid 16
    radio 1: band 0 ant 0 max_ssid 16
    ethernet_device_event: dev eth0 is up
    ASAP Slowpath initialized
    Starting watchdog process...
    Getting an IP address...
    DHCP timed out.
    Retrying with etbonding: bond0: Could not set eth0 as active slave; either eth0
    is down or the link is down.
    h0 as active link.
    Please help me make the AP standalone.
    Thanks in advance.
    uv.
  • 2.  RE: convert ap-225 to standalone
    Posted Feb 17, 2016 06:56 AM
    That seems to be a Campus AP-225 and not an IAP.  It will only work with a controller and cannot be converted to standalone mode.
