Convert AP-325 to IAP-325
This thread has been viewed 51 times
  • 1.  Convert AP-325 to IAP-325
    Posted Mar 19, 2020 11:12 AM
    Hi, I am pretty new to this and need some help.
    I am IT tech at a big school and we have around 100 IAP-305 but some problem in certain areas. Therefore I have bought in two AP-325 and two AP-335 but by mistake instead of Instant AP:s.
    As I understand it is now from some months ago possible to convert them to IAP:s. I do not have a controller because they are centralized managed. Can this be done without a controller? I have IAP-325:s can I use one of them as a controller to convert the AP:s? I can use the app Bluconsole to acess the AP:s but I do not know if I can use it for this and how?
    Can anyone support with some ideas or point to some instructions?
    Thanks in advance
  • 2.  RE: Convert AP-325 to IAP-325
    MVP EXPERT
    Posted Mar 19, 2020 11:42 AM
    There is no supported method of converting an AP to an IAP. You would need a controller to use the AP model.
    There is a few select 3xx series APs which are Unified APs (and subsequent models after) which are Unified APs.
    https://community.arubanetworks.com/t5/Wireless-Access/Is-it-possible-to-convert-AP-325-to-IAP-325/td-p/468112
  • 3.  RE: Convert AP-325 to IAP-325
    Posted Mar 19, 2020 12:45 PM
    Thanks for your answer.
    Ok unified, can mine be applicable bought in two months ago?
    I read this:
    https://community.arubanetworks.com/t5/Controller-Based-WLANs/Reset-the-AP-from-controller-mode-to-IAP-mode-through-Controller/ta-p/519209
    .. and thought that could be doable in my case?
  • 4.  RE: Convert AP-325 to IAP-325
    MVP EXPERT
    Posted Mar 19, 2020 12:48 PM
    It would have to be an IAP model in the first instance. Unless it was purchased as an IAP-325 it cannot be converted to an IAP.
    https://blogs.arubanetworks.com/solutions/aruba-unified-ap-platform/
    Easiest way to tell is to check the sitcker on the back, it would have IAP. Here's also the datasheet so you can check the part number.
    https://www.arubanetworks.com/assets/ds/DS_AP320Series.pdf
