Convert AP back to IAP
  • 1.  Convert AP back to IAP
    Posted Mar 04, 2014 01:46 AM
    I would like to REMOTLY convert my IAP105 back to being instant. I had previously changed it to work as a CAP.
    Now I know you can use the console port to purge save reboot etc or that you can use the reset hole/button to revert to IAP. I however would like to do this remotely as it's not ideal to travel to branches and take APs off the roof or where ever they have been placed.
    Is this at all possible?
    Kind Regards,
    Brendon
  • 2.  RE: Convert AP back to IAP
    Posted Mar 04, 2014 04:23 AM
    Sorry,No - After i been converted to be normal AP,u got two options:
    via console port / reset button.
  • 3.  RE: Convert AP back to IAP
    Posted Mar 04, 2014 04:19 PM
    Please consider in the future Eth<-> Serial Console converter like that:
    https://www.digi.com/products/serialservers/digionesp
