last person joined: 3 hours ago
Convert AP175 to instant mode
  • 1.  Convert AP175 to instant mode
    Posted May 09, 2014 11:51 AM
    Hi!
    I have two AP175 (AC and PoE) and just realized that there are in mode to works with mobility controller, can I convert them to instant mode. It is possible to convert from mobility controller level (I have MC 200 with ArubaOS 5.0)? I tried to convert them from console but it is blocked (permission denied). Please help ;)
    Thanks in advance
  • 2.  RE: Convert AP175 to instant mode
    Posted May 09, 2014 11:54 AM
    You cannot, unfortunately.
  • 3.  RE: Convert AP175 to instant mode
    Posted May 09, 2014 12:04 PM
    Ok, thanks for quick reply ;)
  • 4.  RE: Convert AP175 to instant mode
    Posted May 09, 2014 12:07 PM
    The short answer is no. Please see this thread for details: click here
  • 5.  RE: Convert AP175 to instant mode
    Posted May 13, 2014 04:27 AM
    I've one question yet. Does mount kit is the same in AP175 and IAP175? I have to send back AP175 to distributor but I don't know if mount kit send back too. Thanks in advence!
  • 6.  RE: Convert AP175 to instant mode
    Posted May 13, 2014 07:38 AM
    Yes, same mount.
  • 7.  RE: Convert AP175 to instant mode
    Posted May 13, 2014 07:42 AM
    Thanks!
