Aruba Central
Convert AP515 to CAP
This thread has been viewed 22 times
  • 1.  Convert AP515 to CAP
    Posted Mar 14, 2022 05:16 PM
    So I can not seem to find any documentation on how to convert AP515 in Central to CAP. Only documents I find say, go to Maintenance and then Convert. Apparently that option is not available. This really should not be this complicated, ideally central should just have an option to convert the AP.
    Ali
  • 2.  RE: Convert AP515 to CAP
    MVP GURU
    Posted Mar 14, 2022 05:19 PM
    First you must remove the central license assigned to the AP. If it is part of a cluster, you may need to put it on its own VLAN/Subnet (not the same as the other central managed APs.) as well.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: Convert AP515 to CAP
    Posted Mar 14, 2022 05:34 PM
    I just found your other post on this topic lol, thank you.
    Ali
