Convert CAP to IAP
This thread has been viewed 66 times
  • 1.  Convert CAP to IAP
    Posted Aug 05, 2021 08:36 AM
    Hi
    i have 5 AP-314 CAP i would like to convert them to IAP
    i tried to do it from the controller by running #ap redeploy controller-less but it give me error message say this command is not available for this model
    base on the below document , AP-314 is not UAP which is not supported by this command
    https://www.arubanetworks.com/techdocs/CLI-Bank/Content/aos8/ap-rdply-cntrles.htmap redeploy controller-less
    so can i know how i can convert AP-314 from CAP to IAP
    Joe Jim
  • 2.  RE: Convert CAP to IAP
    MVP EXPERT
    Posted Aug 05, 2021 09:08 AM
    This command only works with UAPs and as per the doc:
    The ap redeploy controller-less command works only for UAPs and is applicable to AP-203HAP-203RAP-203RPAP-303AP-303H303P SeriesAP-318AP-344AP-345AP-365AP-367AP-374AP-375AP-377AP-387AP-534, and AP-535 access points only.
    If you are running ArubaOS 8.6 and above, you can still convert APs to IAPs with a few caveats.
    https://www.arubanetworks.com/techdocs/ArubaOS_86_Web_Help/Content/arubaos-solutions/access-points/conv-ap-iap.htm?Highlight=convert%20to%20instant%20mode
    Craig Syme
  • 3.  RE: Convert CAP to IAP
    Posted Aug 10, 2021 06:53 AM
    Thanks Craig
    I had go through the steps but when i run # Show AP active status i got error (Pre Validate Failed ) is that  mean IAP image is not compatible with the CAP
    thanks
    Joe Jim
