Convert IAP-103 to Campus MMC/M3 Fails
  • 1.  Convert IAP-103 to Campus MMC/M3 Fails
    Posted Oct 16, 2015 09:32 PM
    Having trouble getting IAP-103's to convert to an M3 controller.  Move AOS up and down and InstantOS up and down until my last attempt was ArubaOS_MMC_6.4.0.2_42757, and ArubaInstant_Pegasus_6.4.0.2-4.1.0.0_44004
    Since the FTP session isn't interactive, I don't know how to query the directory for the mips32.ari file.
    --00:15:40--  ftp://sap:*password*@10.4.159.253/mips32.ari
      (try: 3) => `mips32.ari'
    Connecting to 10.4.159.253:21... connected.
    Logging in as sap ...
    Error in server greeting.
    Giving up.
    Target : 94:b4:0f:c3:4a:d2
    show vpn status
    profile name:default
    current using tunnel                            :unselected tunnel
    ipsec is preempt status                         :disable
    ipsec is fast failover status                   :disable
    ipsec hold on period                            :600
    ipsec tunnel monitor frequency (seconds/packet) :5
    ipsec tunnel monitor timeout by lost packet cnt :2
    ipsec     primary tunnel crypto type            :Cert
    ipsec     primary tunnel peer address           :N/A
    ipsec     primary tunnel peer tunnel ip         :N/A
    ipsec     primary tunnel ap tunnel ip           :N/A
    ipsec     primary tunnel current sm status      :Init
    ipsec     primary tunnel tunnel status          :Down
    ipsec     primary tunnel tunnel retry times     :0
    ipsec     primary tunnel tunnel uptime          :0
    ipsec      backup tunnel crypto type            :Cert
    ipsec      backup tunnel peer address           :N/A
    ipsec      backup tunnel peer tunnel ip         :N/A
    ipsec      backup tunnel ap tunnel ip           :N/A
    ipsec      backup tunnel current sm status      :Init
    ipsec      backup tunnel tunnel status          :Down
    ipsec      backup tunnel tunnel retry times     :0
    ipsec      backup tunnel tunnel uptime          :0
    end of show vpn status
    show upgrade info
    Image Upgrade Progress
    Mac                IP Address  AP Class  Status       Image Info                        Error Detail
    94:b4:0f:c3:4a:d2  10.1.77.70  Pegasus   downloading  ac-ftp://10.4.159.253/mips32.ari  Retrieve image fail
    94:b4:0f:c3:4e:22  10.1.77.71  Pegasus   downloading  ac-ftp://10.4.159.253/mips32.ari  Retrieve image fail
    Auto reboot           :enable
    Use external URL      :enable
    end of show upgrade info
    show log upgrade
    ----------Download log start----------
    Executing '/aruba/bin/download_image_swarm ac-ftp://10.4.159.253/mips32.ari --no-proxy X-Ap-Info:CU0113714,94:b4:0f:c3:4a:d2,AP-103'
    fetching ('/usr/sbin/wget -T 120 -t 3 --no-proxy --header=X-Ap-Info:CU0113714,94:b4:0f:c3:4a:d2,AP-103 -a /tmp/download_url_log ftp://sap:x@10.4.159.253/mips32.ari')
    --02:03:03--  ftp://sap:*password*@10.4.159.253/mips32.ari
               => `mips32.ari'
    Retrying.
      (try: 2) => `mips32.ari'
    Retrying.
    Giving up.
    Error: failed to retrieve image
    cleaning up
    done
    ----------Download log end------------
    Download status: Retrieve image fail
    ----------Upgrade log start----------
    upgrade log not available
    ----------Upgrade log end------------
    Upgrade status: upgrade status not available
    end of show log upgrade
    show log rapper
    Rapper info not available
    end of show log rapper
    Target : 94:b4:0f:c3:4e:22
    show vpn status
    ipsec hold on period                            :0
    show upgrade info
    94:b4:0f:c3:4e:22  10.1.77.71  Pegasus   image-ok  kk          none
    Auto reboot           :enable
    show log upgrade
    Executing '/aruba/bin/download_image_swarm ac-ftp://10.4.159.253/mips32.ari --no-proxy X-Ap-Info:CU0114138,94:b4:0f:c3:4e:22,AP-103'
    fetching ('/usr/sbin/wget -T 120 -t 3 --no-proxy --header=X-Ap-Info:CU0114138,94:b4:0f:c3:4e:22,AP-103 -a /tmp/download_url_log ftp://sap:x@10.4.159.253/mips32.ari')
    --00:28:29--  ftp://sap:*password*@10.4.159.253/mips32.ari
               => `mips32.ari'
    Retrying.
    Retrying.
    Giving up.
    cleaning up
    done
    show log rapper
  • 2.  RE: Convert IAP-103 to Campus MMC/M3 Fails
    Posted Oct 17, 2015 12:38 PM
    Please use newer OS on the instant itself and on your controller , be sure your IAP can contact your controller / if using control plane security - make sure , the AP is allowed. Check that u get enough license on the controller. ALSO and most importent - if your IAP belong to speseifc region and your controller belong to different region , it will not work also (for example IAP-103-JP will not work in front of 3200XM-IL controller)
