Convert IAP to RAP error
  • 1.  Convert IAP to RAP error
    Posted May 20, 2013 12:37 PM
    I am trying to convert my RAP3 from instant to a RAP.
    I am running 6.1.3.6 on the controller and just updated the IAP to the most recent
    I am getting this error from show log security 30
    May 20 09:59:12 :133019: <ERRS> |localdb| User BF0018856::00:0b:86:82:e7:fd was not found in the database
    May 20 09:59:12 :133006: <ERRS> |localdb| User BF0018856::00:0b:86:82:e7:fd Failed Authentication
    But I see it in the database
    show local-userdb-ap
    00:0b:86:82:e7:fd  default   00:0b:86:82:e7:fd                                           Provisioned                    Fri May 17 09:45:23 2013  Yes      0.0.0.0
  • 2.  RE: Convert IAP to RAP error
    Posted May 20, 2013 12:55 PM
    You need 6.2 or 6.1.4.x on your controller to support the RAP3s
  • 3.  RE: Convert IAP to RAP error
    Posted May 21, 2013 10:47 AM
    Any thing I should know about before goint to to 6.1.4?  Unfortunaletly my controller is a 3200 without the mem upgrade so 6.2 is not a possibility.
  • 4.  RE: Convert IAP to RAP error
    Posted May 21, 2013 10:48 AM
    You should read the 6.1.4.x release notes in the Aruba support site
  • 5.  RE: Convert IAP to RAP error
    Posted Jul 15, 2014 04:30 PM
    I get the same problem Converting IAP to CAP on AOS 6.3.1.5
    Jul 15 13:45:00  localdb[1630]: <133006> <ERRS> |localdb|  User 18:64:72:ce:a4:10 Failed Authentication
    Jul 15 13:45:09  localdb[1630]: <133006> <ERRS> |localdb|  User 18:64:72:ce:9c:43 Failed Authentication
    (GA-2462-DO-WCTRL) (config) #show ver
    ArubaOS (MODEL: Aruba3200-US), Version 6.3.1.5
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2014, Aruba Networks, Inc.
    Compiled on 2014-04-08 at 20:23:43 PDT (build 43118) by p4build
    ROM: System Bootstrap, Version CPBoot 1.3.1.0 (build 35189)
    Built: 2012-09-06 16:05:33
    Built by: p4build@re_client_35189
  • 6.  RE: Convert IAP to RAP error
    Posted Jul 15, 2014 04:32 PM
    Add that mac address to the controller's whitelist.
  • 7.  RE: Convert IAP to RAP error
    Posted May 20, 2013 03:26 PM
    what is the code versopn on your controller becuase we need  AOS 6.1.4.1 to bring up RAP-3 on the controller
