Convert IAP to RAP problem
  • 1.  Convert IAP to RAP problem
    Posted Oct 10, 2013 10:44 AM
     I am running ArubaOS version 6.2.1.4 on my Aruba 6000 controller. When I try to convert an IAP to a RAP using the webUI I receive the following error message on the controller when I do a "show log security"
    Oct 10 08:18:19 :133006:  <ERRS> |localdb|  User d8:c7:c8:c8:04:fc Failed Authentication
    Oct 10 08:18:40 :133019:  <ERRS> |localdb|  User d8:c7:c8:c8:04:fc was not found in the d
    atabase
    Can anyone let me know what I am doing wrong?
  • 2.  RE: Convert IAP to RAP problem
    Posted Oct 10, 2013 10:50 AM
    Have you white listed the particular RAP in the RAP-WHITElist on this controller ?
    If yes, double check the MAC addr.
    JF
  • 3.  RE: Convert IAP to RAP problem
    Posted Oct 10, 2013 10:55 AM
    I have not that. How do I get to the RAP-Whitelist? Is it under Security>Authentication?
  • 4.  RE: Convert IAP to RAP problem
    Posted Oct 10, 2013 11:00 AM
    Navigate to
    Configuration / AP Installation and you should see "RAP White-list"  or "White-list RAP"
    JF
  • 5.  RE: Convert IAP to RAP problem
    Posted Oct 10, 2013 11:03 AM
    ..and a screenshot to help out
    JF
  • 6.  RE: Convert IAP to RAP problem
    Posted Oct 10, 2013 11:08 AM
    Thanks a million! This was my first RAP!
  • 7.  RE: Convert IAP to RAP problem
    Posted Oct 10, 2013 11:10 AM
    Here to help anytime.
    RAPs are great ... lots of fun ;)  and fantastic solution for remote site/teleworker.
    JF
