Convert IAP105 to AP105
  • 1.  Convert IAP105 to AP105
    Posted Aug 03, 2016 12:52 PM
    Hey all,
    I have been trying to convert this pesky iap105 to an AP105 for the past few days now. from the command line, i have tried running the convert-aos-ap command specifying the mode and aruba-master, then i get errors in the log saying:
    connecting to device.aruba-networks.com
    handshake try again
    failed ssl handshake returned 0000001
    every now and then a stream of messages come up saying
    ####:error:14094418:lib(20):func(148):reason(1048):NA:0:ssl alert number 48
    now i see that the clock is set to jan 1 2000, I tried setting the clock and that didn't do much. I'd really like to get this AP working so I can deploy it. thanks!
  • 2.  RE: Convert IAP105 to AP105
    Posted Aug 03, 2016 01:01 PM
    Have you tried to reset via the reset button? Just curious...otherwise, bring it up on an isolate network with no internet access (say on a laptop with a DHCP server, then once up, you can run the convert command).
  • 3.  RE: Convert IAP105 to AP105
    Posted Aug 03, 2016 01:10 PM
    I have run the clear os command, the factory_reset command, the erase commands, and my master isn't even seeing it come online. it came online yesterday but i assigned it to an ap-group and then when it rebooted, it wasn't in my aruba-master.
  • 4.  RE: Convert IAP105 to AP105
    Posted Aug 03, 2016 01:50 PM
    Hey there, I tried to convert it on a lab network, but it can't connect to the aruba master (which is in my data center with about 300+ ap's connected to it.
  • 5.  RE: Convert IAP105 to AP105
    Posted Aug 11, 2016 11:18 AM
    Found the solution. I ran out of licenses  so it wouldn't let the conversion from IAP to RAP finish.
