Convert Virtual to Fisical Controller.
  • 1.  Convert Virtual to Fisical Controller.
    Posted Oct 30, 2014 09:08 AM
    Hi Guys,
    I have a doubt about of how to Convet Virtual to Fisical Controller.
    Will the fisical controller import the SSIDs from the virtual controller or I must reconfigure it?
    Thank you.
  • 2.  RE: Convert Virtual to Fisical Controller.
    Posted Oct 30, 2014 09:11 AM
    Do you mean converting an Instant AP to a controller-based AP?
    Yes, you would need to recreate your network configuration on the controller.
