Aruba Apps
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
Converting an existing iOS app to work in Workspace
  • 1.  Converting an existing iOS app to work in Workspace
    Posted Sep 06, 2013 10:21 AM
    Anybody have an idea what it takes to convert an existing customer specific application and convert/recompile/whatever it to run in ClearPass Workspace ?
    Regards
    Ronnie
  • 2.  RE: Converting an existing iOS app to work in Workspace
    Posted Sep 06, 2013 10:26 AM
    Looks like all of the information is available in the App Developer portal at http://arubanetworkskb.force.com/DeveloperPortal
  • 3.  RE: Converting an existing iOS app to work in Workspace
    Posted Sep 06, 2013 10:52 AM
    Error: Insufficient Privileges :(
    I also registered as a developer (or at least tried to) on the 30th August.
    Regards
    Ronnie
  • 4.  RE: Converting an existing iOS app to work in Workspace
    Posted Sep 06, 2013 11:09 AM
    If this is an internal (enterprise) app, not published to the App Store, then there is no need to modify the app in any way. Simply upload the .ipa file to the ClearPass WorkSpace server. The conversion process is automatic. Prior to upload of the app, you will have to configure ClearPass with an Apple Distribution Certificate and Provisioning Profile.
  • 5.  RE: Converting an existing iOS app to work in Workspace
    Posted Sep 06, 2013 11:15 AM
    Making progress - thanks.
    Seems the app is published to the App Store. How does that change the process ?
    Regards
    Ronnie
  • 6.  RE: Converting an existing iOS app to work in Workspace
    Posted Sep 06, 2013 11:25 AM
    If the app is published to the App Store, then the app developer needs to register in the Aruba WorkSpace ISV program. This gets them access to our WorkSpace toolkit which is used to produce a "for Aruba" version of their app which can then be published to the public App Store or the B2B store depending upon the situation.
  • 7.  RE: Converting an existing iOS app to work in Workspace
    Posted Sep 06, 2013 01:55 PM
    Thanks, sort of what I expected. Now if I can only get detail on the "toolkit" to pass on to possible customer :(
    Regards
    Ronnie
