Converting IAP to Campus AP fails - Retrieve Image Failed
This thread has been viewed 58 times
  • 1.  Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted May 11, 2017 03:10 AM
    We have the following:
    - Mobility Controller 7024 - on AOS 6.5.1.2
    - IAP275
    Via instant we try to voncert the IAP275 to Campus AP managed by controller. After hitting the button CONVERT it says 'downloading information form controller'.
    After a while it shows us the message in Instant:
    - Retrieve image failed, please save the log in the popup window. AP will reboot in 15 minutes.
    We don't see a log. So I don't know wha tis going wrong?
    #7024
    #6.5
  • 2.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Jun 20, 2017 02:14 AM
    Hi Christian,
    Off late, have you got any resolution?
    I am as well facing the same issue. I am running on: (MODEL: Aruba7240XM), Version 6.5.0.2.
    I have converted few 315 IAPs to Campus and it worrked fine, however when I am trying to convert the rest I am as well facing the same issue as yours.
  • 3.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    MVP EXPERT
    Posted Jun 20, 2017 03:10 AM
    Do you see any errors in the logs on the CLI of the controller or IAP? Are there any firewalls between the IAP and controller which  maybe blocking ports?
  • 4.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Jul 19, 2018 04:33 AM
    I have the same problem as the person asking the question. My AP and controller is on the same subnet, and the VMC is a 8.2.1.0 OS. The AP is an iap305, so compatibility shouldn't be a problem.
    In the log file it says:
    Connecting to 172.20.205.1:21... failed: No route to host.
    Error: failed to retrieve image
    But I can ping the controller from AP. And as I said, there is no firewall between them. CPsec is enabled, Auto cert provisioning is disabled, but the AP is in the whitelist and in Approved state.
    Any Ideas where to start?
  • 5.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
  • 6.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Jul 20, 2018 04:00 AM
    Hello!
    I know how to convert ap. Thats why I have a problem. Because after trying to convert it fails with an "failed to retrieve image" error.
    Daniel
  • 7.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Jul 20, 2018 06:35 AM
    Hi;
     To see the registry, try to see if it is possible that you have blocked the pop-up window. The firmware download is by FTP, so then you need verification if this port is open between IAP to controller.
    I hope that helps.
  • 8.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Jul 20, 2018 07:23 AM
    I put a factory default AP of the same type (ap305) on the port and it came up as instant. Then did converting and it joined controller. So I doubt its a network connectivity error, or a port being closed off. I tried the AP with test controller and it joined. So I think its a stuck config on the controller side.
    Is there a way to purge all config from controller regarding one specific AP?
  • 9.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Jul 23, 2018 03:58 AM
    You need to upgrade the controller to newer firmware to support that model.
    6.5.1.2 did not support.
  • 10.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Jul 23, 2018 04:02 AM
    I am runnig  VMC 8.2.1.0. So I don't think its a controller firmware problem.
  • 11.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Jul 23, 2018 06:30 AM
    If the controller is running 8.2.1.0, I have no idea.
    Could you try to upgrade IAP to latest version first then convert to join the controller?
  • 12.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Jul 23, 2018 06:50 AM
    I have also tried to set up a same VMC in test environment, converted, then provisioned the AP. Then took it to client and still it fails to connect. (Of course, I changed the master IP to client's controller first.)
    I also tried a few firmwares. Upgraded and downgraded the AP but ended up with same result. The AP connects to other controllers except client controller. I also tried hooking up a different AP to the same physical port and it converts. So I ruled out network problem.
    I also had an intresting phenomenon. I also put a laptop in the same subnet as the AP and controller. I could ping the controller from laptop and back. I could ping AP from laptop and back. But I couldn't ping either the controller from AP or the other way around. Thats why I thought the controller has somehow blacklisted the ap (even though the AP is in whitelist accepted status) and is blocking traffic.
    If someone has an Idea wheather this is possible. I am open to suggestions.
    THX
    Daniel
  • 13.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Jul 23, 2018 07:04 AM
    Did you try to change Regulatory Domain?
  • 14.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Jul 23, 2018 07:08 AM
    Every appliance runs on HU regulatory domain. Before trying to convert AP I set it also to HU.
  • 15.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Jul 23, 2018 10:08 PM
    Please try to create another regulatory domain for testing. Maybe US, SG. Just for testing.
  • 16.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Jul 24, 2018 09:50 AM
    In a productive environment I don't know if its possible.
  • 17.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Jul 24, 2018 09:59 AM
    If it is a connectivity issue, it probably is not related to the regulatory domain.
    Please open a TAC case to save yourself some time:  https://www.arubanetworks.com/support-services/contact-support/
  • 18.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Aug 24, 2018 08:37 AM
    Hello Everyone!
    Just an update, because I saw that other people had the same problem as me, so I thought I share my results.
    I opened a TAC case side-by-side with this thread. TAC confirmed my hunch that it was a hardware problem:
    When the AP boots:
    [    0.428064] msm_pcie_probe: msm_pcie_probe: PCIe: RC0 is not enabled during bootup; it will be enumerated upon WAKE signal.
    [    0.428074] msm_pcie_probe: msm_pcie_probe: PCIe: Driver probe failed for RC0:-1
    [    0.429137] msm_pcie: probe of 80000.qcom,pcie failed with error -1
    Also, when AP boots, its routing table is all messed up. Sometimes it would erase the default-gw adress and set it to 0.0.0.0.
    So that was the big mystery. A faulty hardware :)
    Cheers!
  • 19.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Jan 23, 2019 02:56 PM
    I was having the same problem with a few cases of IAP325's. My Controller running version 6.5.4.9 and IAP's coming with 6.4.4.4....
    Updated the IAP's to 6.5.4.9 and resolved the problem.
  • 20.  RE: Converting IAP to Campus AP fails - Retrieve Image Failed
    Posted Oct 11, 2019 10:39 AM
    Old post but i just hit this snag as well and it wasnt a hardware issue which was listed..
    After some show commands I noticed I missed some config..
    MC# show crypto ipsec sa
    Oh the AP has an inner ip of 0.0.0.1
    but I made my VPN Pool...
    show log all 30.. Okay it uses the default-vpn-role and uses L2TP
    Go to the default-vpn-role ->More-> L2TP field is EMPTY. Make sure the L2TP drop down has your VPN Pool selected :D
    TFTP is used between RAP and MC btw for image updates
    Reboot AP, convert again,. Boom - Correct inner IP and conversion successful.
