converting IAP to CAP fails
  • 1.  converting IAP to CAP fails
    Posted Mar 14, 2013 10:38 AM
    is there a known issue with converting an IAP 105 running  Version 6.2.0.0-3.2.0.2 build 37229 to a CAP? or am i missing something basic?
    i have tried many times and it fails with an error like "Response data is corrupted, Request URL part: long string with IP and mode" all the time, via CLI (console) didnt work either. eventually i downgraded to an old version 5.x something and it worked right away. so connection and such is fine. controller is a 650 running 6.2, but with 6.1 it failed too.
  • 2.  RE: converting IAP to CAP fails
    Posted Mar 07, 2014 11:00 AM
    Having the same with RAP-108. Did you fix this ? May I know how or what I can try more ?
    Thanks, regards
      Alex
  • 3.  RE: converting IAP to CAP fails
    Posted Mar 07, 2014 08:19 PM
    I've not experienced that myself, but that is also an older IAP code base. IAP-105 is good for CAP conversion from anything from IAP 1.0 forward on controllers running 6.1.4.x + . Perhaps give something in the GA 3.4 strema a try, if that fails - best to capture the error and lob an email into TAC.
    From the IAP 4.0 User Guide:
