Converting Instant config to Controller based config?
  • 1.  Converting Instant config to Controller based config?
    Posted Jul 01, 2019 06:51 AM
    Hi All,
    I wondering about is there a Tool from Aruba that helps the transformation of an Instant system to a controller based system?
    I need to build the exact same confguration on the mobility controller that runs on Instant Virtual Controller (with many wlans, dynamic vlans, lots of auth servers and specified radio settings).
    Thanks!
  • 2.  RE: Converting Instant config to Controller based config?
    Posted Jul 01, 2019 08:29 AM
    There is no tool that I am aware of.
    Consider building it from scratch to obtain a clean configuration on the controller side.
  • 3.  RE: Converting Instant config to Controller based config?
    Posted Jul 01, 2019 09:26 AM
    I started to build a configuration from zero.
    I thought one question was worth it. :)
  • 4.  RE: Converting Instant config to Controller based config?
    Posted Jul 01, 2019 09:44 AM
    Absolutely worth it.
